auldreekie Posted August 19, 2019 Share Posted August 19, 2019 Does TCS automatically enable when starting engine and should it be left on permanently? I assume when the TCS lamp comes on on the dash it indicates it's either off or a fault, is that correct? Quote Link to comment Share on other sites More sharing options...
sioneon Posted August 19, 2019 Share Posted August 19, 2019 It'll be on if you turn it off or if you somehow force it to kick in when driving hard, not sure if it's on if there is a fault. Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted August 20, 2019 Share Posted August 20, 2019 If it stays on when you start or stays on while driving it indicates a fault, most commonly with the ABS sensors. If it comes on while driving it indicates it’s in use. Quote Link to comment Share on other sites More sharing options...
