Focus Mk1 H7 bulb replacement
Quick heads up Guys.Had to replace this bulb front headlight passenger side.Most recommend remove headlight.Time consuming and likely followed by MOT alignment failure I would think. Rob your wife’s makeup bag and nick her little mirror to get view of back of light.Bulb clip is like a hinged spring(Think safety pin here) Don’t disturb the hinge but wiggle clip side loose.Refit new bulb ,replace clip.Its fiddly and a pig to see but quicker this way I would think.Good luck!!
Mark the fixings and mounting points with a pencil before you remove headlamp, then you make sure it goes back in the same place.
a few years ago I bought a mirror for doing things like this. a dentist type mirror on a telescopic stick (slides out like an old style car aerial). Very cheap on ebay. Useful thing to have in your tool box.
