AU10L00 Posted September 14, 2019 Share Posted September 14, 2019 How do you tell if you have Sync 2 or Sync 3 headunit? Ive not got the manual for the car yet... Focus 67reg. Thanks in advance Quote Link to comment Share on other sites More sharing options...
dtulip8 Posted September 14, 2019 Share Posted September 14, 2019 A 67 reg should definitely be a SYNC3, if it has a blue and white colour scheme as opposed to red and black then it’s SYNC3. 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 15, 2019 Share Posted September 15, 2019 Sync2-Sync3-Sent from my SM-G965F using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
avi Posted September 15, 2019 Share Posted September 15, 2019 16 hours ago, AU10L00 said: How do you tell if you have Sync 2 or Sync 3 headunit? Ive not got the manual for the car yet... Focus 67reg. Thanks in advance Do you know the manufacturing build date of the car ? If it's October 2016 of later it should be Sync 3, and it's easy to spot because the versions look different, with Sync 3 having icons in a line along the bottom of the display to select the different functions, such as "Apps", which Sync 2 doesn't. Unfortunately there can be a big difference between when a car is built, which determines spec, and when its first registered. 2 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted September 15, 2019 Share Posted September 15, 2019 Would Sync version come up on ETIS? You can run the VIN of the car on the ETIS website to list the spec. You can also do this by reg number by following this method: http://www.fordgalaxy.org.uk/ford/index.php?/topic/26546-ford-etis-reg-lookup-trick/ Quote Link to comment Share on other sites More sharing options...
mastachaz Posted September 15, 2019 Share Posted September 15, 2019 over 66 must be sync 3 1 Quote Link to comment Share on other sites More sharing options...
AU10L00 Posted September 15, 2019 Author Share Posted September 15, 2019 Legends all of you. Thanks. Sync3 it is! 2 Quote Link to comment Share on other sites More sharing options...
