Tylorim18 Posted September 17, 2019 Share Posted September 17, 2019 I've installed the mk3.5 steering wheel in my mk3 focus and was expecting the arrow and "ok" buttons to control the mfd but it all controls the radio and now I cant access vehicle settings etc does anyone have a guide on how to control the mfd instead of the stereo? I've literally just forked out 180 on the steering wheel and airbag seems a shame to not work properly. https://imgshare.io/image/XDNJH This is the new setup. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 17, 2019 Share Posted September 17, 2019 Apart from the MK3.5 steering wheel you also need to install a MK3.5 Steering Wheel Control Module (wich is integrated into the clockspring assembly). Next to this the settings of the Central Car Configuration needs to be changed to the correct settings for the new MK3.5 steering wheel. 2 Quote Link to comment Share on other sites More sharing options...
Tylorim18 Posted September 17, 2019 Author Share Posted September 17, 2019 13 minutes ago, JW1982 said: Apart from the MK3.5 steering wheel you also need to install a MK3.5 Steering Wheel Control Module (wich is integrated into the clockspring assembly). Next to this the settings of the Central Car Configuration needs to be changed to the correct settings for the new MK3.5 steering wheel. Any chance you could send the part number over and I'm guessing the latter is done with focccus? If it is done with focccus can you tell me what I would have to change my car is as follows: 2011 Ford Focus ZETEC 1.6 TDCi 115bhp Standard stereo with dab bt and voice control Level 2 instrument cluster Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 17, 2019 Share Posted September 17, 2019 I see that your car does not have Cruise Control. In this case you might be very lucky. Your MK3 Steering Wheel Control Module might support the MK3.5 steering wheel buttons. Just change Central Car Configuration setting number 187 (Audio Buttons On Steering Wheel) and see if this solves the problem. I suspect that this setting needs to be set to hexadecimal value 03. 1 Quote Link to comment Share on other sites More sharing options...
Tylorim18 Posted September 17, 2019 Author Share Posted September 17, 2019 9 minutes ago, JW1982 said: I see that your car does not have Cruise Control. In this case you might be very lucky. Your MK3 Steering Wheel Control Module might support the MK3.5 steering wheel buttons. Just change Central Car Configuration setting number 187 (Audio Buttons On Steering Wheel) and see if this solves the problem. I suspect that this setting needs to be set to hexadecimal value 03. Is this done in ForScan or Focccus? I've ordered the modified ELM unit to do it and have plenty of experience with VCDS, TECH2 and NCSExpert but I've never played with the ford software. Also all the buttons work that's not the issue, the issue is that the arrow and "ok" buttons control the radio and not the Multifunction Display on the instrument cluster. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted September 18, 2019 Share Posted September 18, 2019 This thread just reminded me why the last time I changed a steering wheel was on my 1995 Celica GT4 to a nice MOMO leather one. Modern cars are just far too much hassle LOL Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted September 18, 2019 Share Posted September 18, 2019 I have nothing of value to add, but I'm gonna poke @Luke_Anderson here. I believe he has put the facelift steering wheel on his and might be able to help you out? Quote Link to comment Share on other sites More sharing options...
Luke_Anderson Posted September 18, 2019 Share Posted September 18, 2019 Being a 2011 I guess you had the early steering wheel with the separate audio controls, sadly I had the later steering wheel so mine worked fine first time only had to change the clock spring for the cruise to work. I’d change the spring for a facelift one as well and then if that doesn’t work look at the settings in forscan 1 Quote Link to comment Share on other sites More sharing options...
Tylorim18 Posted September 19, 2019 Author Share Posted September 19, 2019 14 hours ago, Luke_Anderson said: Being a 2011 I guess you had the early steering wheel with the separate audio controls, sadly I had the later steering wheel so mine worked fine first time only had to change the clock spring for the cruise to work. I’d change the spring for a facelift one as well and then if that doesn’t work look at the settings in forscan Cheers mate I was trying to look for wiring diagrams to rewire the buttons to the mfd signal wires myself but couldn't find anything. Quote Link to comment Share on other sites More sharing options...
Luke_Anderson Posted September 19, 2019 Share Posted September 19, 2019 To be honest they don’t really work like that anymore, I’m fairly confident changing the clockspring will sort all that out for you Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 19, 2019 Share Posted September 19, 2019 The steering wheel switches are basically resisitance switches where every button has a different resistance. When no buttons are pressed the switches have a reference resistance. Depending on the type of switches and the combination of switches the resistance will be different. Depending on the resistance value the The Steering Wheel Control Module is able to detect the presence of the steering wheel switches and which particular button of the switches is pressed. Based on this information the Steering Wheel Control Module generates a CANbus message that is communicated to the ACM, IPC, PCM, etc. 1 Quote Link to comment Share on other sites More sharing options...
Tylorim18 Posted September 19, 2019 Author Share Posted September 19, 2019 All done guys, installed the new instrument cluster at the same time, opened up Focccus and programmed in some new features changed option 187 to audio buttons on steering wheel and now everything works perfect. 🤗 Next up is the Mk3.5 Sync 2 with touchscreen unit retrofit and some ST seats before I start on the exterior. Thanks for everyones help. Heres how it looks now: https://imgshare.io/image/sb1cf 1 Quote Link to comment Share on other sites More sharing options...
Botus Posted September 19, 2019 Share Posted September 19, 2019 cruise control would be a good idea.... Quote Link to comment Share on other sites More sharing options...
FordFocus3 Posted January 8, 2020 Share Posted January 8, 2020 Hey everyone! So Ive got an ugly Mk3 wheel (with cruise) and would like to throw on a lovely Mk3.5 one. I hear that I need the steering wheel module? What does this look like? Cheers! Also, does Focccus work with any old ELM bluetooth adaptor? Quote Link to comment Share on other sites More sharing options...
Petrou99 Posted January 1, 2021 Share Posted January 1, 2021 (edited) On 9/19/2019 at 5:20 PM, Tylorim18 said: All done guys, installed the new instrument cluster at the same time, opened up Focccus and programmed in some new features changed option 187 to audio buttons on steering wheel and now everything works perfect. 🤗 Next up is the Mk3.5 Sync 2 with touchscreen unit retrofit and some ST seats before I start on the exterior. Thanks for everyones help. Heres how it looks now: https://imgshare.io/image/sb1cf Hey, I'm in the process of doing the same upgrade and have the same issue as you had. When you say you changed 187 to audio buttons on steering wheel what exactly do you mean? Only asking because the audio buttons on steering wheel are 187 so assuming I need to change the last numbers of that block? Mine is apparently set to 03 looking at the as-built information from etis. Which I would also assume is the correct settings. What did change in that setting please. I'm using ForScan also. Thank you in advance, appreciate any help. Yiannis Petrou Edited January 1, 2021 by Petrou99 Quote Link to comment Share on other sites More sharing options...
Mash11 Posted March 26 Share Posted March 26 On 9/19/2019 at 5:20 PM, Tylorim18 said: All done guys, installed the new instrument cluster at the same time, opened up Focccus and programmed in some new features changed option 187 to audio buttons on steering wheel and now everything works perfect. 🤗 Next up is the Mk3.5 Sync 2 with touchscreen unit retrofit and some ST seats before I start on the exterior. Thanks for everyones help. Heres how it looks now: https://imgshare.io/image/sb1cf Hi mate, I’m having the same problem, do you have to change the instrument cluster or just the settings will work fine ?? Please let me know!! Quote Link to comment Share on other sites More sharing options...
unofix Posted March 26 Share Posted March 26 13 minutes ago, Mash11 said: Please let me know!! Expect a long wait ...... Quote Link to comment Share on other sites More sharing options...
Mash11 Posted March 26 Share Posted March 26 27 minutes ago, unofix said: Expect a long wait ...... I just sorted it out!! Over the moon!! 1 Quote Link to comment Share on other sites More sharing options...
