SD card\Sync 2
Could someone let me know if I can change the sd card from one car to another. The situation is that we have a Focus titanium x (on a 15 plate) which is sync 2 and has Sat Nav and we have a Kuga titanium x (16 Plate) which is also Sync 2 which does not have sat nav. The 2 screens and  set up are identical. Is it possible just to take the card from the focus and load it into the kuga without causing any problems? We don't really need Sat in the Focus but I would like it in the Kuga.
@kmoore04uk in general the SDcard is not connected to the specific vehicle so you can try also in Kuga without causing any damage.
But the SDcard holds only EU maps not the navigation itself. So if Sync2 in Kuga is a non nav unit (in the top right corner it says "system information" instead of "navigation") it won't work at all because simply, it is a non nav unit. But there is a way how to enable the sat nav in Sync2 and it requires a very very little bit of programming viab OBD port, so if you might wanna try just PM me.
Cheers
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
Apologies for hijacking this thread. I’m new and a new owner as well. I too have just purchased a 2016 titanium sport with sat nav. Where is the sd card located? I pick it up on Sunday morning btw. I noticed there was one in the center rest next to 2 usbs. But it didn’t feel like there was a sd card in there. The navigation was working as well.
  • 3 months later...
On 9/22/2019 at 11:05 AM, Stoney871 said:
You can transfer the card across but is nav enabled on the other car?
If not then contact@Bannko, he'll guide you through setting it up.
@Bannko can you contact me please as I also require your help
  • 1 month later...
  • 6 months later...
Hi, please can someone assist me. I have a 2017 66 plate with Sync2 but no nav, I've read a few posts saying you can activate the nav system, how do I do this please? Any help will be massively appreciated
  Only 75 emoji are allowed.
  • Create New...
