mr
this morning i went to use my fob to unlock my 15 plate ford focus. it wouldnt work so i then tried manually unlocking my ford. it wont unlock ??? any suggestions. also its not the battery in the fob as ive tried using both my key fobs
The only thing I can think of is a flat car battery, but the car should still at least unlock the driver door mechanically by using the key???
not sure but if you locked it with the deadlocks on, would it still unlock by turning the key in the lock? not sure if it's designed to or not. Anyone else know?
Yes, deadlocks can still be opened with the manual key, you do need to turn it a bit more firmly though.  Just don't go so far as to snap it!
