Brian Griffin 56 Posted October 6, 2019 Share Posted October 6, 2019 2004 mondeo new starter motor fitted by garage, drove less than 1/4 mile car stopped, started after a short while ran for a few seconds then stopped, no warning lights on garage towed car back to garage, diagnostic gave code for injectors, bought second hand injectors had them coded but car wouldn't start so but the bullet and had my original ones reconditioned by specialists , fitted injectors and had them coded yippee, car started (smiles all round) then it stopped again tired several times seems like same problem exists, whilst standing neer engine after it had stopped i heard a sort of rushing, girgle sound coming from the new fuel filter, tried running car with filler cap off still no joy,removed inlet pipe from filter no diesel spilled out, decided to fill Jerry can with diesel fed filter direct from can bypassing tank and feed pipes, car started an kept running fine using nearly all 5leters of fuel,any suggestions to help me get my pride and joy back on the road, thanks in advance. Quote Link to comment Share on other sites More sharing options...
nicam49 Posted October 12, 2019 Share Posted October 12, 2019 Hi, the leakoff pipes have O rings on them where they go into the injectors. If you get just one O ring not sealing right, then air gets into the fuel pipe system and causes what you're experiencing. Inspect the green O rings carefully, I think some eBay sellers do replacements. Also, the fuel pipe O rings on the connectors to the fuel filter can get damaged but I've only personally experienced the leak-off pipe problem. btw, you need diesel-proof ones, not 'normal' black O rings. 1 Quote Link to comment Share on other sites More sharing options...
