johnH Posted October 14, 2019 Share Posted October 14, 2019 Just to let people know it is possible to install the ACV Qi Charger into the MK4. Basic steps are: 1. Pull gear gator up (its clipped) 2. Remove gear gator surround (the one with buttons on) 3. Pull trim on passenger side out (again clipped in) 4. Drivers side. Remove small circle trim to access 6mm bolt. Remove and pull trim. Now there is also 2x torx screws (1 each side) and the tray with usb and aux port should lift up...bearing in mind wires. 5. Unclip all wires and on the bottom of the phone tray is plastic honey combing...use a craft knife to remove. 6. Stick on wireless charger and connect harness up. 7. Put it all back together and enjoy cable free...unless u use android auto or apple carplay. https://shop.ford.co.uk/collections/other-infotainment-accessories/products/acv-qi-wireless-charging-kit-universal-kit?model=focus&year=2018 2 Quote Link to comment Share on other sites More sharing options...
Ams Posted October 14, 2019 Share Posted October 14, 2019 Hi JohnH, Excellent guide buddy. Thank you so much. Is it possible for you to attache some pictures with this guide as it will help? Thank you once again. Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted October 14, 2019 Share Posted October 14, 2019 Theres a YouTube guide to fitting a pad to a Fiesta https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DZPgh4_LrR_0&ved=2ahUKEwiK__DGrJzlAhUMUlAKHaIsBzIQwqsBMAR6BAgEEA0&usg=AOvVaw1XNPPk2p1DCW8HVeI1GUL0 Although not exactly the same the trim removal is similar enough to give you an idea. I'm interested to know how sensitive this pads charging is to the phone moving around as this is the problem with the factory fitted item that stopped me having one on my car Quote Link to comment Share on other sites More sharing options...
johnH Posted October 14, 2019 Author Share Posted October 14, 2019 Ill get some pics/videos uploaded tomorrow. In terms of phone moving i did a journey from gateshead to darlington using a mixture of roads such as dual carriageways, motorway and even rallied it around a country road and the phone hardly slid around on the rubber mat. Ive got a Samsung s9 with the Samsung fabric case. Quote Link to comment Share on other sites More sharing options...
Gaz4482 Posted November 28, 2019 Share Posted November 28, 2019 Hi John, I've a focus active and I was thinking about getting a wireless charger could I please see your pics and videos Quote Link to comment Share on other sites More sharing options...
johnH Posted November 29, 2019 Author Share Posted November 29, 2019 Here is a quick install guide, with pics. It is in PDF format so you will need adobe reader to view. FordFocusQiInstall.pdf 3 1 Quote Link to comment Share on other sites More sharing options...
Gaz4482 Posted November 30, 2019 Share Posted November 30, 2019 Thanks John much appreciated Quote Link to comment Share on other sites More sharing options...
Paulofalcon Posted February 16, 2020 Share Posted February 16, 2020 Hello! Can you tell if it’s possible remove the side panels without remove the gear gator? Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Marceel Posted May 21, 2020 Share Posted May 21, 2020 Article is a few months old and the link to the pdf document doesn’t work anymore. does anyone have a copy that can be reposted or send it to me by email? Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted May 22, 2020 Share Posted May 22, 2020 I just downloaded it again OK. https://www.fordownersclub.com/applications/core/interface/file/attachment.php?id=72429 Quote Link to comment Share on other sites More sharing options...
Kimbie Posted June 19, 2020 Share Posted June 19, 2020 The link to the product seems dead, is this the same item https://shop.ford.co.uk/collections/all/products/qi-wireless-charging-kit-universal-kit Thanks Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted June 19, 2020 Share Posted June 19, 2020 Yes Quote Link to comment Share on other sites More sharing options...
Monks600 Posted June 19, 2020 Share Posted June 19, 2020 Wish they came up with something like this for the MK3, possibly in the arm rest or something. Or I’d happily get rid of the cup holders for this! Great find :)Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
DannykEN7 Posted June 28, 2020 Share Posted June 28, 2020 On 10/14/2019 at 12:55 PM, johnH said: Just to let people know it is possible to install the ACV Qi Charger into the MK4. Basic steps are: 1. Pull gear gator up (its clipped) 2. Remove gear gator surround (the one with buttons on) 3. Pull trim on passenger side out (again clipped in) 4. Drivers side. Remove small circle trim to access 6mm bolt. Remove and pull trim. Now there is also 2x torx screws (1 each side) and the tray with usb and aux port should lift up...bearing in mind wires. 5. Unclip all wires and on the bottom of the phone tray is plastic honey combing...use a craft knife to remove. 6. Stick on wireless charger and connect harness up. 7. Put it all back together and enjoy cable free...unless u use android auto or apple carplay. https://shop.ford.co.uk/collections/other-infotainment-accessories/products/acv-qi-wireless-charging-kit-universal-kit?model=focus&year=2018 Hi there, new to the forum, so go easy on me 😬 I’ve installed the same charger as you, but find it very rarely charges. It will charge for about 5 seconds then stop, really driving me crazy!! What I would like to know, if it would be possible to order the original tray with wireless charge pad that would come if ordered from factory? If so, would you or anyone know part numbers needed? Thanks in advance, and sorry if this has been covered elsewhere. Quote Link to comment Share on other sites More sharing options...
Bob28809 Posted August 20, 2021 Share Posted August 20, 2021 So they have brought a decent one of the qi wireless kit out that is actually for the mk4. part number is 2452297 (£80), just make sure you get the new style mat as well, stops your phone sliding about so much. part no. 2424210(£11). At the moment they show as out of stock online but when i went to my local dealer they had it there in a couple of hours.. Hope this helps someone👍 Quote Link to comment Share on other sites More sharing options...
Mark2jag Posted September 10, 2022 Share Posted September 10, 2022 This info is very useful for me as about to buy a 69-plate ford focus Vignale with everything except wireless charging.... How could ford justify a Vignale top of the range model allegedly with everything and then not include wireless charging, however video strip down and reassembly would be most helpful, as I'm just about ok at changing a fuse, and that's it. Cheers. Mark Quote Link to comment Share on other sites More sharing options...
Mark2jag Posted September 10, 2022 Share Posted September 10, 2022 When I posted my question i didn't know the subject had been gone into in such depth, but I wanted to know if anyone would be able to do or point me in the direction of a video how to highlight fitting the wireless charger on an automatic 69 plate model with the rotary gear changer, which looks like it might be a bugger to get apart. I also want to know what Kenny meant when he said..."7. Put it all back together and enjoy cable free...unless u use android auto or apple carplay."...... Kenny if you are reading this, whats the deal with that comment?? Is it because the current drain when using Android Auto means it cannot keep up with the drain on the battery?? Quote Link to comment Share on other sites More sharing options...
unofix Posted September 10, 2022 Share Posted September 10, 2022 Wireless charging it's useless if you're using android auto, the phone is discharging rather than charging ! Quote Link to comment Share on other sites More sharing options...
Mark2jag Posted September 10, 2022 Share Posted September 10, 2022 Thanks for the reply Unofix. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted September 11, 2022 Share Posted September 11, 2022 If you are using android auto it will be plugged in to USB and charging from the cable instead. Quote Link to comment Share on other sites More sharing options...
tomo2001 Posted September 11, 2022 Share Posted September 11, 2022 On 10/14/2019 at 9:16 PM, Comares2001 said: Theres a YouTube guide to fitting a pad to a Fiesta https://www.google.co.uk/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DZPgh4_LrR_0&ved=2ahUKEwiK__DGrJzlAhUMUlAKHaIsBzIQwqsBMAR6BAgEEA0&usg=AOvVaw1XNPPk2p1DCW8HVeI1GUL0 Although not exactly the same the trim removal is similar enough to give you an idea. I'm interested to know how sensitive this pads charging is to the phone moving around as this is the problem with the factory fitted item that stopped me having one on my car The phone moving issue is fixed by a new design rubber mat, now available from Ford Quote Link to comment Share on other sites More sharing options...
Mark2jag Posted September 12, 2022 Share Posted September 12, 2022 Thank you all for the replies. I have an AA wireless device so can use my note 20 ultra wirelessly, thats why the big deal about a wireless charger. In a very strange set of circumstances I can connect my phone wirelessly via my AA wireless device, but am unable to connect using a cable, just comes up with a message saying something about connecting and 2 circles rotating, but never does connect.. Now got a much bigger issue to deal with, concerning really poor fuel consumption, on a 1.5 diesel auto.. New post all about it somewhere on here.... Quote Link to comment Share on other sites More sharing options...
