Strange noise under the cam belt cover
Replaced a set of wet belt , cam belt  and auxiliary belt some 6.5k miles ago. Used Dayco kits. Recently engine developed a strange dull, grinding noise in all driving conditions. There's no issues with the car performance.
Any suggestions what the problem may be? Cheers!!!
Anyone? Any ideas?
This grinding noise is from the direction of the cam/belt cover, aux.belt. Happens after engine warms to the normal operating temperature and the sound intensity stays the same despite the varying rpm. I'm scratching my head.....
Have u checked the cover is not getting scraped?
I wonder if it's the engine mount collapsed?  Everything around the belts all moves in time with RPM, struggling to think of anything else that wouldn't!
Thank you both!!
Shall inspect and post again. TBH engine seem to be vibrating when shut down as well.
Water pump?
Replaced a Ford original with SKF. Anyway goes on the to check list.
