James Posted October 22, 2019 Share Posted October 22, 2019 The glass screen on my fuel gauge is cracked. Is the glass piece easy to replace or would I have to get a new fuel gauge? It's more a cosmetic thing but its annoying to look at ha. The crack has gotten bigger and there are splinters coming from the crack not shown in the picture. Is it worth even replacing? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 23, 2019 Share Posted October 23, 2019 The glass (plastic) is part of the complete instrument cluster and not seperately available. To fix this you either have to replace the complete instrument cluster or buy a donor instrument cluster from eBay and use this to repair your instrument cluster. When buying a donor instrument cluster you have to make sure to buy the correct one. You need a Level 3 instrument cluster (large full color display). The Level 1 and Level 1+ instrument clusters (smaller monochrome display) have a different front part which does not fit to the Level 3 instrument cluster. Quote Link to comment Share on other sites More sharing options...
James Posted October 23, 2019 Author Share Posted October 23, 2019 10 hours ago, JW1982 said: The glass (plastic) is part of the complete instrument cluster and not seperately available. To fix this you either have to replace the complete instrument cluster or buy a donor instrument cluster from Ebay and use this to repair your instrument cluster. When buying a donor instrument cluster you have to make sure to buy the correct one. You need a Level 3 instrument cluster (large full color display). The Level 1 and Level 1+ instrument clusters (smaller monochrome display) have a different front part which does not fit to the Level 3 instrument cluster. Its probably not worth doing then so. Thanks for the info! Quote Link to comment Share on other sites More sharing options...
