Side lights intermittant fault
Near side sidelights front and rear mainly off but sometimes on when switched on for no apparent reason. No interior warning when off
Just me, or does anyone else not really understand what this explanation is trying to describe?? :huh:
i think he is saying that when the sidelight switch is on, the sidelights often don't come on.
could be switch, fuses, connectors on the BCM/body control module.
Do the speedo/ heating control illumination lights go on and off properly with the switch? if they come on and off OK and the sidelights don't then I am thinking that rules out the switch.
I would also suggest it's not the fuse either if they 'sometimes' work. A fuse either works or doesn't...
