Warning Light
Hello
I had to replace the battery on my 2012 Ford Focus today and when I went to lock it tonight there is a red warning light flashing on the dashboard (only noticed it because it was dark).  The light seems to be the same as when there is a door open or a seat belt isn't fastened and the yellow light which appears when you lock the car when you are inside it is also illuminated.  Would be very grateful if somebody could explain what I need to do.
Many thanks
Maxine
If it is the flashing red ! between the dials on the instrument cluster just above the steering column and the yellow light on the lock button on the audio system then that is normal. The red flashing ! indicates that the alarm is set and the yellow led indicates that the doors are locked. It should always have been like that but you haven't noticed it previously. It took me about 2 years to spot it on mine.
