Pug=309 Posted November 15, 2019 Share Posted November 15, 2019 Hi all, I'm looking to convert my disc/drum setup to st disc/disc, but a few sites say that the mk3 has 320mm fronts and and mk3.5 has 335mm, is this correct? Pad size seems to be the same on both (I know it could just be a different caliper barcket) and rears seem to be the same 271mm solid disc, I just would like some clarification before I buy. Thanks Allan Quote Link to comment Share on other sites More sharing options...
Pug=309 Posted November 17, 2019 Author Share Posted November 17, 2019 after doing some research, I have found that the mk3.5 dose have the bigger 335mm discs, and since the pad size for both is the Same, I'm assuming that the caliper carrier is the different part, can anyone confirm this or help with dimensions of the carriers for mk3 and mk3.5? thanks allan Quote Link to comment Share on other sites More sharing options...
