Focus 2012 near side knocking
I have a focus2012 titanium 1.6 petrol
i replaced a broken spring and sinse then I have a knocking noise mostly at low speeds
i have replaced the drop link and it still does it
Anti roll bar ?Tightened all suspension bolts to correct torques?
Not checked anti roll bar yet
would that make that sort of noise
is it an easy job to do
Cheers
If your anti- roll bar is loose then you would definitely here a knocking noise.On my MK1 there are 2 brackets each bracket has a bush,2 bolt holes and fixed to the subframe.Not sure about yours but probably similar 👍
