Conor_mk7 Posted November 18, 2019 Share Posted November 18, 2019 Wanting to lower my red edition to tide me over until I get airride end of next year but don't want coil overs (owned a slammed mk1 mx5 before this and I ruined the underside馃ぃ) the standard setup is very good looking on the red editions but I want it lower, just to get rid of the arch gap.聽 What stress do lowering springs put on the standard shocks and bump stops?聽 Is the ride better than coil overs?聽 Does anyone have any photos of their fiestas on 50mm springs?聽 Quote Link to comment Share on other sites More sharing options...
Gaskell71 Posted November 18, 2019 Share Posted November 18, 2019 Lowering 50mm on standard dampers is a bad idea, ideally you would or should fitted appreciate shortened damps and that level.聽 Best bet to stick with standard dampers and 35mm lowering springs like Eibach pro line of springs. Quote Link to comment Share on other sites More sharing options...
Conor_mk7 Posted November 18, 2019 Author Share Posted November 18, 2019 2 hours ago, Gaskell71 said: Lowering 50mm on standard dampers is a bad idea, ideally you would or should fitted appreciate shortened damps and that level.聽 Best bet to stick with standard dampers and 35mm lowering springs like eibach pro line of springs. Okay can you recommend some dampers to look at? If I'm having to buy dampers I may as well get coil overs maybe? Or rock the 35mm for ease.聽 Quote Link to comment Share on other sites More sharing options...
Conor_mk7 Posted November 18, 2019 Author Share Posted November 18, 2019 I've also just seen Eibach red line springs that lower front by 35mm - 40mm and lower rear by 40mm - 45mm, these look good and I know Eibach springs are designed for standard shocks. Although it does say the springs are for st180 and st200's but I doubt that makes a difference.聽 Quote Link to comment Share on other sites More sharing options...
Gaskell71 Posted November 18, 2019 Share Posted November 18, 2019 Been looking around for you on the Bilstein B12 kit, and your looking at 拢800 excluding fitting and to be honest with you Conner_mk7 would a waste since your planning to change to coil-overs soon anyway.聽 So me personally would keep to standard and save enough unt you can go straight to the coil-overs.聽 Enjoy, I hear good things about the KW kits. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted November 18, 2019 Share Posted November 18, 2019 1 hour ago, Conor_mk7 said: I've also just seen eibach red line springs that lower front by 35mm - 40mm and lower rear by 40mm - 45mm, these look good and I know eibach springs are designed for standard shocks. Although it does say the springs are for st180 and st200's but I doubt that makes a difference.聽 It makes a huge difference, the STs have a much heavier 1.6 engine, the 1.0 barely weighs anything so you wouldn't get anywhere near the same drop. Personally I'd go with the 35s, you can keep standard shocks and they'll be easy to sell on when you get air. Quote Link to comment Share on other sites More sharing options...
Conor_mk7 Posted November 18, 2019 Author Share Posted November 18, 2019 25 minutes ago, TomsFocus said: It makes a huge difference, the STs have a much heavier 1.6 engine, the 1.0 barely weighs anything so you wouldn't get anywhere near the same drop. Personally I'd go with the 35s, you can keep standard shocks and they'll be easy to sell on when you get air. Yeah that's what I'm thinking bud! I know a guy local selling 35mm springs local, but he owns an St will I have the same problem with them?聽 Quote Link to comment Share on other sites More sharing options...
Conor_mk7 Posted November 18, 2019 Author Share Posted November 18, 2019 48 minutes ago, Gaskell71 said: Been looking around for you on the Bilstein B12 kit, and your looking at 拢800 excluding fitting and to be honest with you Conner_mk7 would a waste since your planning to change to coil-overs soon anyway.聽 So me personally would keep to standard and save enough unt you can go straight to the coil-overs.聽 Enjoy, I hear good things about the KW kits. Thank you for the info I think I'll go with the 35mm option until I get air at the end of next year Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted November 19, 2019 Share Posted November 19, 2019 13 hours ago, Conor_mk7 said: Yeah that's what I'm thinking bud! I know a guy local selling 35mm springs local, but he owns an St will I have the same problem with them?聽 Yeah, the fronts won't be as low on yours as they are on his. Quote Link to comment Share on other sites More sharing options...
