Donna white Posted December 3, 2019 Share Posted December 3, 2019 Hi there, looking for some advice please, I have a problem with my front wipers on my mk2 focus. They work some days then others they are stuck on slow mo and if I try to change the speed they just stop in random places. Can anyone shed some light on what to do as I have read that the relay is built in, help please 🤞 Quote Link to comment Share on other sites More sharing options...
andypsp Posted December 3, 2019 Share Posted December 3, 2019 the relay should be in the fuse box, if you look in your owners manual it should say where the relay number is in the fuse box this is the relay part number 5M5T-14B192-AA only £5 new on ebay 😀 Quote Link to comment Share on other sites More sharing options...
Donna white Posted December 3, 2019 Author Share Posted December 3, 2019 I've looked in my owners manual... Only tells u about fuses 😢nothing about relays, can't find anything anywhere. Quote Link to comment Share on other sites More sharing options...
isetta Posted December 4, 2019 Share Posted December 4, 2019 The white plastic fuse box can be removed from the car and taken apart (I don't think ford intend for normal owners to do this). Inside is a circuit board with loads of stuff soldered to it. if I remember correctly the relays are soldered direct to circuit board, they can't just be pulled out and new one slotted in like in the old days. I have taken one apart (to see if it had water damage inside it) but can't recall exactly what it looked like. Electrically this is a complex car compared to some others. Fine when it all works. Very tricky when it plays up. 1 Quote Link to comment Share on other sites More sharing options...
Donna white Posted December 5, 2019 Author Share Posted December 5, 2019 On 12/4/2019 at 2:18 PM, isetta said: The white plastic fuse box can be removed from the car and taken apart (I don't think ford intend for normal owners to do this). Inside is a circuit board with loads of stuff soldered to it. if I remember correctly the relays are soldered direct to circuit board, they can't just be pulled out and new one slotted in like in the old days. I have taken one apart (to see if it had water damage inside it) but can't recall exactly what it looked like. Electrically this is a complex car compared to some others. Fine when it all works. Very tricky when it plays up. Thanks, I reckon I will have to put it in somewhere to be looked at 😒 they started working again today, but I don't think that will last long 🤔 On 12/3/2019 at 5:58 PM, andypsp said: the relay should be in the fuse box, if you look in your owners manual it should say where the relay number is in the fuse box this is the relay part number 5M5T-14B192-AA only £5 new on ebay 😀 Quote Link to comment Share on other sites More sharing options...
