Tonyp3462 Posted December 5, 2019 Share Posted December 5, 2019 I’ve recently bought a mk3 mondeo ST tdci. The passenger side mirror does not fold out into the correct position. Looking at the two mirrors when folded out the drivers side seems to fit tight in its position but the passenger one doesn’t. It also doesn’t move the actual glass freely either. Specifically down and inwards seem to have little effect. does the unit have the motor inside it or is it separate to it ? im thinking I may have to replace the whole unit and if so does the colour coded section come off easily ? Quote Link to comment Share on other sites More sharing options...
pragmatix Posted December 5, 2019 Share Posted December 5, 2019 There is nothing repairable in the mirror unit replacement is the answer yes the cover does come off, its a very easy swop once the door card is removed hard to spot screws in the door handle you need to prise of the handle cover after that it's dead easy one nut hold the mirror on. Quote Link to comment Share on other sites More sharing options...
Tonyp3462 Posted December 5, 2019 Author Share Posted December 5, 2019 53 minutes ago, pragmatix said: There is nothing repairable in the mirror unit replacement is the answer yes the cover does come off, its a very easy swop once the door card is removed hard to spot screws in the door handle you need to prise of the handle cover after that it's dead easy one nut hold the mirror on. Ok I shall see if I can find some videos on YouTube ! Quote Link to comment Share on other sites More sharing options...
Tonyp3462 Posted December 5, 2019 Author Share Posted December 5, 2019 2 hours ago, pragmatix said: There is nothing repairable in the mirror unit replacement is the answer yes the cover does come off, its a very easy swop once the door card is removed hard to spot screws in the door handle you need to prise of the handle cover after that it's dead easy one nut hold the mirror on. Mine is the non puddle light (early 2005) do you know if I got the puddle light mirrors would it need additional wiring ? Quote Link to comment Share on other sites More sharing options...
pragmatix Posted December 6, 2019 Share Posted December 6, 2019 13 hours ago, Tonyp3462 said: Mine is the non puddle light (early 2005) do you know if I got the puddle light mirrors would it need additional wiring ? You may be lucky and the wiring may be there, Quote Link to comment Share on other sites More sharing options...
