Andycclarke Posted December 11, 2019 Share Posted December 11, 2019 Hi I have a 2010 mk7 fiesta and the steering is not recentering I have changed a lot of parts including the rack and is exactly the same could this be a failing steering coloumn I don't want to replace it if it's not goi g to be the issue so can a bad coloumn cause it to not recentre what causes it to pull to the right thanks Quote Link to comment Share on other sites More sharing options...
AndyDC Posted December 11, 2019 Share Posted December 11, 2019 Have you checked the geometry? Not just toe but camber & caster and set-back as these can be detrimental. Quote Link to comment Share on other sites More sharing options...
Andycclarke Posted December 11, 2019 Author Share Posted December 11, 2019 Hi yes i have taken it Many places for wheel Alighnment and all say it's as it should be and no one has told me any different as I have taken it to about 5 different places each place I have been a few times Quote Link to comment Share on other sites More sharing options...
Andycclarke Posted December 11, 2019 Author Share Posted December 11, 2019 Ford told me the rack wasn't recentering so I changed that and it's the same Quote Link to comment Share on other sites More sharing options...
isetta Posted December 11, 2019 Share Posted December 11, 2019 I am no expert. If steering doesn’t self centre I thought it is usually due to too much toe out on the tracking. Has it always done this or did it start doing it after something specific like a part changed or a prang. Quote Link to comment Share on other sites More sharing options...
Andycclarke Posted December 11, 2019 Author Share Posted December 11, 2019 When I got the car It had just had a new spring so I thought the tracking was out so I had the track rod ends replace also drop links wishbones bearings and tyres then the issue I have now stands out more than it did and ford said it was the rack not recentering so I did that and the issue is still there after lots of tracking at different places so it's not leaving much other than the column to me and I'm not an expert but the garage I take it to has told me he doesn't know Quote Link to comment Share on other sites More sharing options...
nicam49 Posted December 11, 2019 Share Posted December 11, 2019 Perhaps it's the bearing on top of the strut where the spring was replaced being too tight...? 🤔 Quote Link to comment Share on other sites More sharing options...
Bobr Posted December 12, 2019 Share Posted December 12, 2019 13 hours ago, Andycclarke said: When I got the car It had just had a new spring so I thought the tracking was out so I had the track rod ends replace also drop links wishbones bearings and tyres then the issue I have now stands out more than it did and ford said it was the rack not recentering so I did that and the issue is still there after lots of tracking at different places so it's not leaving much other than the column to me and I'm not an expert but the garage I take it to has told me he doesn't know Is that one new spring? If so that's where I'd start looking. Quote Link to comment Share on other sites More sharing options...
isetta Posted December 12, 2019 Share Posted December 12, 2019 I have my doubts that it is the column but I admit I do not fully understand exactly how the electric power streering works on these. If I remember correctly the column has electric power steering built into it. Quote Link to comment Share on other sites More sharing options...
Gazcaz Posted December 12, 2019 Share Posted December 12, 2019 I have always changed springs in pairs there ase a few things to consider , steering gear that is too tight or improperly adjusted. ... Sticking or binding components, such as a king pin, ball joint, bell crank or even the steering column can prevent the steering wheel from returning to center after a turn,so check top mount is not to tight...Let us know how you get on oh and tyre pressures are even. Quote Link to comment Share on other sites More sharing options...
Eng_Ahmad1986 Posted December 12, 2019 Share Posted December 12, 2019 on some occasions I have seen a failing steering joint shaft can cause the not-centering issue. ( that's the joint shaft not the whole steering column ) Quote Link to comment Share on other sites More sharing options...
