Ford Focus 66 plate wing mirror lens?
Hi guys. The wife has managed to clip our wing mirror this morning and it’s broke the lens on the wing mirror indicator. Does anyone have a part number or know where to get one? I don’t actually know whether it’s a whole wing mirror replacement?
I bought one from ebay. Search for Ford focus mirror indicator lens. About 6-7 quid. It was a generic copy but fitted well.
Also an excuse to get a fancy LED sequential indicator if you wanted ;)
unless it affects the ability to pass MOT I probably wouldn't bother in case it happens again
Thanks for the replies. For £5-£7 I may as well get it. Are they easy enough to fit? Sequential leds??
They're VERY easy once you have done one. It's an absolute git to fathom at first though if you've never done it but it isn't hard, it's just tool and technique 😅
That part is actually completely separate to the rest of the mirror, so can be swapped quickly and cheaply.. I have a Panther Black myself and picked up the 'Smoked' sequential ones. They do look good... Although there are two versions of led, one is a standard strip of LEDs and the other is a number of separate ones. Take a peek online and you'll find them pretty quickly.
Worth noting, the Mk2.5 is the same mirror unit if it makes your search end up a bit cheaper 😉👌
