Small rear window demister
Peloquin138
Hi, the small rear window that is supposed to demise on my mk3 estate doesn't clear. When I got the car the plug was attached but I knocked it off. I put it back on but it has never worked since. I can't be sure it worked before I unplugged it though.
Is it possible I simply put the plug on the wrong way or would that blow a fuse or something?
I have no idea about wiring issues so don't want to simply try turning the plug around...I don't know if that's even possible.
Any suggestions where/how I could start looking for a problem?
I'm assuming it works when I press the rear heated window button and that they share a fuse. The rear window works fine.
Thanks folks.
Edited by Peloquin138
Edit because my phone has wonky predictive text.
1 minute ago, Comares2001 said:
What small window heater ?
The rear passenger side one. It's heated the same as the rear screen but isn't working. I believe most of the estate models have them.
12 minutes ago, Comares2001 said:
It's an aerial not a window heater
Oh right, cheers. I was told it was to Demist that screen so you could see over your shoulder.
Many thanks.
well thats strange. i thought it was a demister too. the car has an aerial on the roof.  so why does it need window aeral as well
Read my earlier embedded post it's an additional FM antenna.
