Stavros Posted January 5, 2020 Share Posted January 5, 2020 Hi there. Can someone confirme i have SYNC 1.0 (not 1.1) For SYNC 1.0, the last version is 5.9 ? Where Can I found a link please ? Cheers Quote Link to comment Share on other sites More sharing options...
Thanasis Posted January 5, 2020 Share Posted January 5, 2020 Hello Stavros, The sync you have as far as I can tell from the photos is version 1.1. Sync 1.0 has a much “older” look to it... Regards, Thanasis Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 5, 2020 Author Share Posted January 5, 2020 1 hour ago, Thanasis said: Hello Stavros, The sync you have as far as I can tell from the photos is version 1.1. Sync 1.0 has a much “older” look to it... Regards, Thanasis Hello Thanasis. Thank you for your answer. Is it possible to get a link for the update ? Quote Link to comment Share on other sites More sharing options...
Thanasis Posted January 5, 2020 Share Posted January 5, 2020 Sure, follow the instructions from the link below. https://www.ford.co.uk/owner/resources-and-support/sync-bluetooth/update#/ Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 5, 2020 Author Share Posted January 5, 2020 33 minutes ago, Thanasis said: Sure, follow the instructions from the link below. https://www.ford.co.uk/owner/resources-and-support/sync-bluetooth/update#/ Your software is already up-to-date. No action is required. No way by the official website 😞 33 minutes ago, Thanasis said: 1 Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 5, 2020 Author Share Posted January 5, 2020 1 hour ago, Stavros said: Your software is already up-to-date. No action is required. No way by the official website 😞 Thank you for your informations 🙂 Quote Link to comment Share on other sites More sharing options...
fgservo Posted January 6, 2020 Share Posted January 6, 2020 I will leave a link to you download version from 5.9 to 5.11 I will erase the file later, 700mb on google drive is still a bit chunk 5.9 to 5.11 1 Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 6, 2020 Author Share Posted January 6, 2020 7 hours ago, fgservo said: I will leave a link to you download version from 5.9 to 5.11 I will erase the file later, 700mb on google drive is still a bit chunk 5.9 to 5.11 Many thanks for the link. I downloaded it but it doesn't work. Unfortunately, my fiesta has Sync 1.0. I will try to change the APIM system. https://www.befr.ebay.be/itm/FORD-FIESTA-BLUETOOTH-MODULE-2016/153748274649?hash=item23cc1c7dd9:g:RL4AAOSwT9Zd5kkb Did someone try to upgrade ? Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 7, 2020 Author Share Posted January 7, 2020 8 hours ago, fgservo said: I will leave a link to you download version from 5.9 to 5.11 I will erase the file later, 700mb on google drive is still a bit chunk 5.9 to 5.11 fgservo, could you tell me what apim number do you have ? Juste get up to the this menu, you should have EB1T or D1BT. Mine is AM5T. Many thanks Quote Link to comment Share on other sites More sharing options...
fgservo Posted January 7, 2020 Share Posted January 7, 2020 Yes, i see it now, you must have E1BT (Sync 1.1), and you have AM5T (Sync 1.0). DB1T is (Sync 1.1), it will work to. I can't help you with older version. Quote Link to comment Share on other sites More sharing options...
fgservo Posted January 7, 2020 Share Posted January 7, 2020 My car dont have a bluetooth, so i find the loom in eBay and install everything, module that come as AM5T, i never try, i upgrade to last model. I update to 5.9 first and then to 5.11. Everything work flawless. Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 7, 2020 Author Share Posted January 7, 2020 I will try to upgrade it. I think the module is to the right side, close to the glove box. It will probably work after plug and play Quote Link to comment Share on other sites More sharing options...
fgservo Posted January 7, 2020 Share Posted January 7, 2020 Correct, is under the glove box and is plug & play. Remove the fuse, and make the exchange, and put the fuse again, and wait a few minutes Quote Link to comment Share on other sites More sharing options...
Stavros Posted January 8, 2020 Author Share Posted January 8, 2020 20 hours ago, fgservo said: Correct, is under the glove box and is plug & play. Remove the fuse, and make the exchange, and put the fuse again, and wait a few minutes Many thanks 😊 Quote Link to comment Share on other sites More sharing options...
MartyL82 Posted July 2, 2023 Share Posted July 2, 2023 Hi, can anyone please help me? I have downloaded the sync1.1 v5.11 syncmyride folder and the install and auto install files but part way through it flashes up on the screen Installation failed. Any help appreciated Quote Link to comment Share on other sites More sharing options...
MartyL82 Posted July 3, 2023 Share Posted July 3, 2023 Further to my last post here is the pics. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
