GeoffGeoff Posted January 18, 2020 Share Posted January 18, 2020 Hi, Trivial really just curious. Changed from a Style mk2 focus to a Titanium mk4 mondeo. On the old car the lights had a "P" for parking lights setting On the new car there is no "P" setting. Is it not needed? If not why was it on the old lower spec car at all? Thankyou for answering a dull question Geoff Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 18, 2020 Share Posted January 18, 2020 If I remember correctly with the ignition off you could use the indicator stalk to select right or left, also the first setting on the light switch is sidelights. 1 Quote Link to comment Share on other sites More sharing options...
GeoffGeoff Posted January 18, 2020 Author Share Posted January 18, 2020 Yes but my question is, if it's so desirable and/or necessary to have this setting - why is it suddenly not important at all and missed off the newer much more expensive much higher spec Mondeo? Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 18, 2020 Share Posted January 18, 2020 Its a useless function IMHO you can still turn the sidelights on its no different. Quote Link to comment Share on other sites More sharing options...
mozz Posted January 18, 2020 Share Posted January 18, 2020 I remember when there was a separate parking light you could 'trap' in the door window to conform to parking regs in that era, geez, i'm old.. 1 Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 19, 2020 Share Posted January 19, 2020 15 hours ago, mozz said: I remember when there was a separate parking light you could 'trap' in the door window to conform to parking regs in that era, geez, i'm old.. Ah the old clip on ones white one side red the other, glow worms where brighter 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 19, 2020 Share Posted January 19, 2020 Parking lights are still a legal requirement as far as I know...you're meant to use them when parking on any road with a speed limit above 30mph. However, you don't really need a separate switch position for them as long as you can select the sidelights without the ignition on. Quote Link to comment Share on other sites More sharing options...
al2052 Posted January 19, 2020 Share Posted January 19, 2020 (edited) Quote I believe the Law was changed so that parking light was not needed provided parked same way as traffic flow and not against traffic flow, presumably relying on reflectors Don't know why this posted as a quote ? Edited January 19, 2020 by al2052 Quote Link to comment Share on other sites More sharing options...
al2052 Posted January 20, 2020 Share Posted January 20, 2020 On 1/18/2020 at 6:32 PM, mozz said: I remember when there was a separate parking light you could 'trap' in the door window to conform to parking regs in that era, geez, i'm old.. Perhaps you can also remember having to bang the side pillar to make the semaphores lift and sometimes again to make them drop. 2 Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 20, 2020 Share Posted January 20, 2020 10 hours ago, al2052 said: Perhaps you can also remember having to bang the side pillar to make the semaphores lift and sometimes again to make them drop. Certainly can😂 Quote Link to comment Share on other sites More sharing options...
Mark M Posted February 3, 2020 Share Posted February 3, 2020 Guessing you haven't read the manual? Page 50, switch on your sidelights then move the indicator to turn them on on the required side 👍 3 Quote Link to comment Share on other sites More sharing options...
nicam49 Posted February 10, 2020 Share Posted February 10, 2020 On 2/3/2020 at 9:40 PM, Mark M said: Guessing you haven't read the manual? Page 50, switch on your sidelights then move the indicator to turn them on on the required side 👍 As usual, when all else has failed, RTFM ! 1 Quote Link to comment Share on other sites More sharing options...
nicam49 Posted February 10, 2020 Share Posted February 10, 2020 On 1/18/2020 at 5:26 PM, pragmatix said: Its a useless function IMHO you can still turn the sidelights on its no different. The difference is, the P setting just turns on sidelights alone and not number plate or dash lights. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted February 10, 2020 Share Posted February 10, 2020 5 hours ago, nicam49 said: The difference is, the P setting just turns on sidelights alone and not number plate or dash lights. Just turn the sidelights on and set the indicator to the side you need Quote Link to comment Share on other sites More sharing options...
