Ford Focus 2010 1.8
I have a 2010 focus. The interior lights and cigar/power socket isn’t working. I’ve checked the fuses and changed the bulb, but this doesn’t seem to have worked. Is there something else I should check? It’s odd they both stopped at the same time.
Indeed, they're on separate fuses.  When you're in the car with the engine running if you leave a door open, does it show a message on the dash to show that a door is open?
Yeah it states ‘driver door open’ on dash panel.
So it correctly recognises when you open and close a door/boot/bonnet etc?
yes that's right
I don’t get an illuminated symbol - is this what you meant? I just get a message on the information display.
Something is disconnected/loose somwhere.
It may have had an aftermarket head unit or alarm system at some point and something has got dislodged.
Try behind the LHS A-Post trim
LHS under dash (BCM) and behind the radio
