stuk2000 Posted March 27, 2010 Share Posted March 27, 2010 Got a an airbag fault code 51, which is the drivers side seat belt buckle. Changed it for a new one but still get the same problem. Looking on Wikipedia for the code it says, DTC B2434: Driver safety belt buckle switch short circuit to ground. Lamp flash code: 51 Possible Source(s): Driver safety belt buckle switch. Circuit(s). DTC B2435: Driver safety belt buckle switch resistance out of range. Lamp flash code: 51 Possible Source(s): Driver safety belt buckle switch. Circuit(s). DTC B2691: Driver safety belt buckle switch open circuit or short to battery. Lamp flash code: 51 Possible Source(s): Driver safety belt buckle switch. Circuit(s). Can anyone help please?? Quote Link to comment Share on other sites More sharing options...
CAR PARTS EXPRESS Posted March 27, 2010 Share Posted March 27, 2010 It wIll most likely be the wiring to the buckle nipped when moving seat backwards and forwards ... Check the wiring Quote Link to comment Share on other sites More sharing options...
stuk2000 Posted March 27, 2010 Author Share Posted March 27, 2010 It wIll most likely be the wiring to the buckle nipped when moving seat backwards and forwards ... Check the wiring The wiring was ok on the newer one, mad sure the connector under the seat was tight. Where else can I look please?? Quote Link to comment Share on other sites More sharing options...
