Conor_mk7 Posted January 29, 2020 Share Posted January 29, 2020 Hi Guys just wondering how many of you removed this piece to fit a front splitter? As I noticed on extreme style design that they had installed aftermarket splitters without removing this oem part. Yet I go on delta styling and it looks to be drilled out. 🤷♂️ I drilled mine out to get the delta splitter on there without first checking to see if it needs to be removed, I just assumed 🤣 have I made a mistake? 😅 Quote Link to comment Share on other sites More sharing options...
Gazcaz Posted January 29, 2020 Share Posted January 29, 2020 I was going to get one of these, but still cant work out whether it has to have the Front bumper aero foil attached or not.Mine doesnt have the aero foil fitted so did not know whether i need to fit this first then the splitter.. https://www.carenhancementsuk.co.uk/collections/ford-fiesta-mk7-5/products/front-splitter-fiesta-mk7-st-line-zetec-s-facelift-2013-up-1 Quote Link to comment Share on other sites More sharing options...
Gazcaz Posted January 29, 2020 Share Posted January 29, 2020 If its this one you have looked at its not the same as your front bumper ? https://deltastyling.com/buy/ford-fiesta-mk7-5-st-delta-s-r-front-splitter/ Quote Link to comment Share on other sites More sharing options...
Gazcaz Posted January 29, 2020 Share Posted January 29, 2020 If its this one then it does not show the earo foil so should be good to go. https://deltastyling.com/buy/ford-fiesta-mk7-5-zs-delta-s-front-splitter/ Quote Link to comment Share on other sites More sharing options...
eddie eastwood Posted January 29, 2020 Share Posted January 29, 2020 Contact the seller and ask them the question. Quote Link to comment Share on other sites More sharing options...
Conor_mk7 Posted February 4, 2020 Author Share Posted February 4, 2020 On 1/29/2020 at 3:04 PM, Gazcaz said: If its this one you have looked at its not the same as your front bumper ? https://deltastyling.com/buy/ford-fiesta-mk7-5-st-delta-s-r-front-splitter/ Naaa that's the st one and the maxton design front splitters you can remove or keep doesn't matter, I think most people keep the oem splitter on as most people can't be bothered to drill the rivets out. Quote Link to comment Share on other sites More sharing options...
Conor_mk7 Posted February 4, 2020 Author Share Posted February 4, 2020 On 1/29/2020 at 3:14 PM, Gazcaz said: If its this one then it does not show the earo foil so should be good to go. https://deltastyling.com/buy/ford-fiesta-mk7-5-zs-delta-s-front-splitter/ Yeah that's what I thought, just wanted to make sure I hadn't made a mistake 👍 that's the splitter it have 😊 Quote Link to comment Share on other sites More sharing options...
