JanWebster Posted January 30, 2020 Share Posted January 30, 2020 The reversing lights have stopped working and there's now't wrong with the bulbs. I want to check the fuse but, unless I am being particularly dim, I don't seem to be able to find it listed on either the engine or passenger compartment fuse diagrams.. Quote Link to comment Share on other sites More sharing options...
Gazcaz Posted January 30, 2020 Share Posted January 30, 2020 1 hour ago, JanWebster said: The reversing lights have stopped working and there's now't wrong with the bulbs. I want to check the fuse but, unless I am being particularly dim, I don't seem to be able to find it listed on either the engine or passenger compartment fuse diagrams.. Passanger compartment fuse 3 i belive 7.5 amp..i might be wrong or could be reverse switch gone bad,, i think yours is to new for tailgate wiring isues. It will be in your hand book look under index f for fuses... Quote Link to comment Share on other sites More sharing options...
JanWebster Posted January 30, 2020 Author Share Posted January 30, 2020 Your info' is correct for the Mk7.5, but close scrutiny of the Mk 8 owner's handook reveals nothing.🤒 Quote Link to comment Share on other sites More sharing options...
Gazcaz Posted January 30, 2020 Share Posted January 30, 2020 44 minutes ago, JanWebster said: Your info' is correct for the Mk7.5, but close scrutiny of the Mk 8 owner's handook reveals nothing.🤒 Try fuse 13.. Quote Link to comment Share on other sites More sharing options...
aguycalledmal Posted January 30, 2020 Share Posted January 30, 2020 http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O39895&countryCode=USA&languageCode=en&marketCode=US&viewTech=IE&chapterTitleSelected=G1866789&subTitleSelected=G1893598&topicHRef=G1893599&div=f&variantid=6102&vCode=Wf0jxxgahjju23788&vFilteringEnabled=True&userMarket=GBR As you say not listed for the fuse boxes Quote Link to comment Share on other sites More sharing options...
JanWebster Posted January 31, 2020 Author Share Posted January 31, 2020 Solution to the problem found. One bulb was not being gripped tightly enough by the connector. With all the speed humps and the awful state of the roads it was being shaken ever-so-slightly loose. 1 Quote Link to comment Share on other sites More sharing options...
