Headlight self leveling control module
Hi. I've got a 2012 Focus Titanium X with the Xenon headlamps. I've had a problem with water getting into the N/S headlamp. Because of the crazy price of a new headlamp unit i thought I'd try and fix the leak. Ive tried to seal the headlamp around where the lens meets the main unit with various sealants but water still gets in. I've now given up trying to fix it and ordered a new headlamp unit. The water has damaged the ballast control unit now which in turn has damaged the self leveling control module. I know where the ballast control unit is but I cant find where the leveling module is fitted. Can someone please tell me where I'll find it so I can replace it
The HCM (Healight Control Module) is located behind the dashboard below the steering column.
Thanks for your help
Thanks for your help. Do you know if I can get to it without removing the dash
  • 1 year later...
I’ve been getting the same problem on same spec off car water keeps getting in due to recent weather any ideas
