Your Honour Posted February 7, 2020 Share Posted February 7, 2020 Hi guys, I need some advice on front parking sensors if possible please. I have googled and searched the forum but could not find anything. Basically I've been a bit of an idiot and have done some damage to one of the front sensors on my Mk 3 Focus, picture below. Now I was wondering how easy it would be to do this without taking to a garage and what would be involved in replacing this? I'm useless, but my Dad is pretty handy with cars. Also would I need to purchase OEM sensors or would aftermarket ones work? Help appreciated as always. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 7, 2020 Share Posted February 7, 2020 Your sensor probably still works, just needs refitting into the bumper. Quote Link to comment Share on other sites More sharing options...
Your Honour Posted February 7, 2020 Author Share Posted February 7, 2020 It does still work but it's pushed into the bumper cover. When the park pilot comes on the indicator for that sensor stays red and beeps. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 7, 2020 Share Posted February 7, 2020 2 minutes ago, Your Honour said: It does still work but it's pushed into the bumper cover. When the park pilot comes on the indicator for that sensor stays red and beeps. Thought so, all you need to do is push it back through the bumper. If the holder ring has been lost or smashed, you'll need to replace that. If you remove the plastic triangle on the bumper (just pull it) you may find you can reach the sensor without even removing the bumper. 2 1 Quote Link to comment Share on other sites More sharing options...
Your Honour Posted February 7, 2020 Author Share Posted February 7, 2020 Thanks for the advice, I'll give this a go later and report back. 👍 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 7, 2020 Share Posted February 7, 2020 The holder ring pushes in from the front then the sensor clips in from the rear.Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Your Honour Posted February 9, 2020 Author Share Posted February 9, 2020 Couldn't get the triangle out by pulling it, done some research and there are clips. I've ordered some trim tools from amazon. Will give it a go when they arrive. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9, 2020 Share Posted February 9, 2020 You could try removing the headlight instead...not sure if that'll give you enough access. Quote Link to comment Share on other sites More sharing options...
Col66 Posted March 25, 2020 Share Posted March 25, 2020 Did you fix your parking sensors? Quote Link to comment Share on other sites More sharing options...
Your Honour Posted March 31, 2020 Author Share Posted March 31, 2020 Hi Guys, Sorry to bump an old thread, did not want to start a new topic. I've got plenty of time do this work atm with the current situation. I hope everyone is keeping safe and well. Anyway I have done the paint work and took the triangle out and can see I can easily reach to pop the sensor back into a new retainer but cannot find the part for my 2013 Mk3 Focus anywhere. Could any of you guys help with this at all? Closest I could find is this and assumed it would not fit? https://www.ebay.co.uk/i/273421524194 Thanks. Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted March 31, 2020 Share Posted March 31, 2020 Take a look at the below link which should show you what part number you need 😊 https://ford.7zap.com/en/car/53/code.dr/0/1770/16389/71503/ Quote Link to comment Share on other sites More sharing options...
Your Honour Posted March 31, 2020 Author Share Posted March 31, 2020 2 hours ago, jlawes20389 said: Take a look at the below link which should show you what part number you need 😊 https://ford.7zap.com/en/car/53/code.dr/0/1770/16389/71503/ Very helpful thanks. however I cannot find anyone in the UK that sell them online anywhere? Quote Link to comment Share on other sites More sharing options...
jlawes20389 Posted March 31, 2020 Share Posted March 31, 2020 I struggled to find the rear ones when I was fitting sensors to my partner's car recently. I ended up having to purchase them from a main dealer. Quote Link to comment Share on other sites More sharing options...
Your Honour Posted April 1, 2020 Author Share Posted April 1, 2020 Okay, may have to get in touch with them then when the current situation dies down then. Quote Link to comment Share on other sites More sharing options...
