Can key fob be upgraded (keyless)
Can my key fob be upgraded to new style of not emitting signal when still which I believe newer ford's have?
Mine is 2017 mk3. 5
If it can any idea price.
Only Focus 2018 on or Fiesta 2017 on  £72 + labour for programming .
Ah OK. Thanks
I'm looking at a car at the weekend for a friend that doesn't like keyless entry, it's a Titanium X 2015, and I believe it *could* be as simple as pulling a fuse in the boot but I'm unsure if it will work so easily yet but will let you know.
It's a fuse listed as just the keyless entry, so the usual button locking/unlocking should work as normal with no detriment.
Will update as I find out more if the storm doesn't put the journey off..
Mine is 2017 mk3. 5
Comares 2001 is right about price. It is another £70 odd to have it programmed. Very expensive replacement. I didn’t know you couldn’t replace slightly older car keys.
I like keyless entry. It's the older fobs like mine emit thier code constantly I don't like as open to scanning. The new ones switch off after a while until they sense movement and then come to life. For the most this avoids scanning and nicking off your driveway.
The reason I asked is the article I had read said some manufacturers offer to convert for free or a small charge. Obviously not Ford then.
I have the newer fob, but still keep it in a blocker pouch
If you buy a decent ELM lead to connect to the OBD and install Forscan you can switch keyless (passive) entry off yourself
Still leaves the hatch keyless, see #5
https://www.focusstoc.com/forums/topic/563443-disabling-some-conveniences/?hl=%2Bkeyless+%2Bentry
  • 1 year later...
Can you tell me how you got it ? I have spoken to my dealer and Ford uk and they haven’t a clue what I’m on about . Mine is a 2020 fiesta and the fob looks like the new type but the new type says won’t work over 2 metres and mine opens the car at 10 metres
Leave the fob somewhere solid near the car for a minute or two.  (Not in your pocket as it'll move).  Then try to open a door keylessly.  It shouldn't work until you move the keyfob.
The dealership has now emailed me back saying the new fob is only standard on the ST line and to upgrade it is £46 fob and £66 to program it
That's odd.  I'm pretty sure all the Focus's with keyless entry have had the motion fob for a couple of years now.  I'm guessing they mean ST rather than ST-Line.  Which spec is yours?
Thanks Tom
just done the test . Put it on the floor 2 metres from car and I could unlock it . Locked it back up and left fob in same place 40 seconds not moved and I couldn’t open the door so I think it does have the motion sensor even though the dealer says he checked my vehicle and it didn’t . I’m confused though as I thought the new fob would not operate over 2 metres and I can still unlock my car from 10 metres
St line X edition
Mine is 2017 mk3. 5
I was told my fiesta can be and it’s £46 inc vat for the fob and £66 inc vat to re program it that’s each key
Mine is 2017 mk3. 5
I was quoted by Sandicliffe Ford £46 each fob and £66 each fob to re program inc vat
33 minutes ago, Julianford said:
Thanks Tom
2 metres is for the keyless entry only.  The fob buttons will still unlock it from 10m away if that's what you mean?
Hi Tom yes . The test was over 2 metres the car won’t unlock even if the fob is moved . Within 2 metres of moved the car unlocks but if left 49 sec or more even next to the car it won’t unlock with your hands .
the remote still unlocks at distance.
is this the latest security fob ?
Yes, that's the latest 'sleepy' motion sensing fob.
Your dealership sounds about as useful as door edge protectors... :biggrin:
Great thanks mate and yes there as useful as a chocolate fire guard . This forum is allot more help 👍
Always is.
