pjung Posted February 24, 2020 Share Posted February 24, 2020 Hi All, I have a Ford Focus MK2 2.0 l petrol car. I tried for curiosity to write the odometer on my car with FORScan. I was able to increase the km value, but not to decrease it from the "odometer write" menu. Than I tried to use the menu under IC programming, called "write odometer value in km" or so. As I wrote the former value from this menu, the decreasing also didn't succeeded, but many problems came instead of. The problems I got: - auxiliary heater failure (the car isn't equipped with such that) - EPB malfunction (the car isn't equipped with such that) - a lot of configurations altered (chime beeping continuously in reverse gear; speed warning chime at 120 km/h; the 5 km/h offset is gone; the engine is cutting off at 7000 RPM - normally it could run up to 8000 RPM - ; I got an extra menu item, "hill launch assist", which would be nice, if it would work) - And the worst of all, the ESP and ASR are completely gone. It doesn't shows up like a failure, it is invisible for the system. Even the check light won't show up when I set the car on ignition. I tried to reprogram all the systems with IDS, but it doesn't helped, I could only get rid of the reverse gear warning, the auxiliary heater, and EPB warning (I set the last 2 to unequipped). The other nasty problems are still there, and the car won't recognize that she has an ESP and ASR. I used the newest version (2.3.29) of FORScan, with VXDIAG VCX nano, for the odometer write procedure. The car is a Ford Focus MK2 2.0 l petrol version, with 145 HP / 107 kW, from 2005, engine code is AODA, the ECU is a Visteon ESU13 5M51-12A650-SD 3CGD. Could someone please help me with this issue? With some AS built data, or maybe with a factory default flash image for the systems in the car, or something, which can revert those to the original state. Quote Link to comment Share on other sites More sharing options...
