rossmcv Posted March 30, 2010 Share Posted March 30, 2010 hi there i have an R reg fiesta 1.25SI and it is idling at about 900 but shakes quite badly then evens out when moving. other issue is its drinking petrol like nothing else, probably a full tank is doing 100 miles (no exageration) ive taken it to two garages who have both scratched their heads saying it may be a hole in an air pipe or the timing is out etc all of which they can investigate but the cost will be high and theres no guarantee of it being corrected after it. has anyone heard of these symptoms before? and if so how is it remeded? other suggestions is that its a faulty sensor in the engine which is causing it to squirt fuel so then im worried if my CAT converter is going to go next with all the fuel firing through it any help will be much appreciated Thanks Rossmcv Quote Link to comment Share on other sites More sharing options...
ace Posted March 31, 2010 Share Posted March 31, 2010 I don't know if this will help but my dad has had the same sort of problem with his diesl 51 reg fiesta and the garage found that one of the fuel injectors was not working well. Quote Link to comment Share on other sites More sharing options...
andy64 Posted April 2, 2010 Share Posted April 2, 2010 hi there i have an R reg fiesta 1.25SI and it is idling at about 900 but shakes quite badly then evens out when moving. other issue is its drinking petrol like nothing else, probably a full tank is doing 100 miles (no exageration) ive taken it to two garages who have both scratched their heads saying it may be a hole in an air pipe or the timing is out etc all of which they can investigate but the cost will be high and theres no guarantee of it being corrected after it. has anyone heard of these symptoms before? and if so how is it remeded? other suggestions is that its a faulty sensor in the engine which is causing it to squirt fuel so then im worried if my CAT converter is going to go next with all the fuel firing through it any help will be much appreciated Thanks Rossmcv Sounds as if it isn't firing properly on one of the cylinders - that will lead to uneven idling & increased fuel consumption. Yes - this could damage the catalytic converter, unfortunately. Suggest a compression check (damaged / worn piston rings, valves or head gasket?), or it could be just a faulty spark plug or (if your car has them) a faulty plug lead or maybe the coil pack? Or a faulty injector. Hope it's something straightforward! Quote Link to comment Share on other sites More sharing options...
