Ford Focus MK1 2004 - Rear Suspension (Please Help)
Did you read my reply? I gave you a finis code of a Ford nut. If you want a quality product then go for an oem one everytime.
Update:
I’ll be buying the bolt from FORD.
I want to pair it with a nut - correctly ( no guessing). I need to know for sure - that any NUT I source - has the proper/correct pairing for that particular thread pitch.
How to verify that a nut - is the correct pairing for a specific bolt - is where I’m getting stuck.
Granted it needs to be a flanged lock nut. I need to understand how to establish, that the threads of the bolt & nut are indeed correctly matched.
My fear is that there will be quite a few nuts that will seem to fit the bolt - even though they are the wrong pairing.
How do I ensure any Nut I get - is actually the right one?
So you're buying a bolt from Ford.Why wouldn't Ford supply an appropriate nut if you ask? 🙄
Update:
Bolt is definitely:  M12 x 1.75 pitch thread - grade 10.9 steel.
However the nut is definitely not just another ny-lock nut. It uses a different system - with some other insert - in place of a nylon one.
I suspect this specifically chosen because of the extreme vibration the joint goes through:
Can anyone help me identify this type of lock nut nut - and help me find the correct variant?
Cheers
Presumably it avoids using nylock due to the heat from the weld.
