Black strips
Hello chaps can the black strips down either side of the roof on MK3 focus be removed for cleaning.
Yes they can be removed without any problems.
The plastic trim is held in place by several plastic retaining clips that are clipped into the plastic trim. The trim can be removed by gently pulling it upwards starting at the back of the car. The clips are part of the trim and not sperately available as a spare part. The clips are quite fragile and easily break so I recommend to remove the plastic trim either on a warm day or in a warm garage to avoid broken clips.
Once the plastic trim is removed you should clean the roof under the trim and inspect the bonded roof/side panels for cracked adhesive. Cracked adhesive at this location is a well known problem of the Focus MK3/MK3.5 and can result in a leaking roof or rust. Cracked adhesive can easily be fixed by applying bodywork adhesive or even ordinary polyurethane or silicone sealant.
Thanks Wilco think I might leave them in place and clean as best I can
