Arkhangelsk1989 Posted March 24, 2020 Share Posted March 24, 2020 Hello, I have a mk6 fiesta zetec s with the standard 16inch zetec s alloys and was wondering if the mondeo 300mm brake upgrade will fit easily under the 16inch alloys without any modification? Thank you Quote Link to comment Share on other sites More sharing options...
KrisT Posted March 25, 2020 Share Posted March 25, 2020 12 hours ago, Arkhangelsk1989 said: Hello, I have a mk6 fiesta zetec s with the standard 16inch zetec s alloys and was wondering if the mondeo 300mm brake upgrade will fit easily under the 16inch alloys without any modification? Thank you Hmmm.... Do want as well. New brakes are on my to do list. Might as well fit something better for roughly the same price, keep me updated if you find out. https://www.ebay.co.uk/c/1663251397 1 Quote Link to comment Share on other sites More sharing options...
Arkhangelsk1989 Posted March 25, 2020 Author Share Posted March 25, 2020 Will do mate 👍🏻 Quote Link to comment Share on other sites More sharing options...
Frembrit Posted March 25, 2020 Share Posted March 25, 2020 There seems to be plenty of info out there... I used Focus ST170 discs and calipers on my MK2 Mondeo when I had that (I've sold the setup a while ago). Just thought it was easier to keep disc and caliper from one vehicle rather than discs from a Focus and calipers/pads from a mk3 Mondeo. The 300mm setup fit behind the ST24 16" alloys (which are chunky), though I was using ST170 17" alloys most of the time. They made a difference to the Mondeo so they should be epic on a Fiesta 😀 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted March 25, 2020 Share Posted March 25, 2020 Won’t it upset balance between front and rear? 1 Quote Link to comment Share on other sites More sharing options...
Frembrit Posted March 25, 2020 Share Posted March 25, 2020 I can't answer that but I've seen on other forums where people have fitted the ST170 rear discs/calipers too to their Fiesta. Certainly no problem on my Mondeo's. 1 Quote Link to comment Share on other sites More sharing options...
Arkhangelsk1989 Posted March 25, 2020 Author Share Posted March 25, 2020 Thank you for the help, really appreciate it 👍🏻 Quote Link to comment Share on other sites More sharing options...
Eatonm112 Posted January 14, 2021 Share Posted January 14, 2021 I have a Mk7 Fiesta with 16 inch wheels so I wanted to see if I could get Focus ST 170 disks with the Mondeo calipers and here is the result. https://photos.app.goo.gl/LPzsxtir9ChMqiVBA https://photos.app.goo.gl/xH4cLjC71jezLtHj9 Results are great much better than the Fiesta ST set up I had before. I have the standard Fiesta ST set up on the rear but plan to change the disks to the 280mm ones from a Focus ST170. Pic of bracket https://photos.app.goo.gl/yPDGWoUEtXeDax28A Quote Link to comment Share on other sites More sharing options...
Arkhangelsk1989 Posted January 15, 2021 Author Share Posted January 15, 2021 21 hours ago, FiestaForever said: Did you get this sorted? Not sure about Mondeo 300mm brakes for fiesta but you can get 300mm st150 brake upgrade for all fiesta models and all that is needed is the widen the bore on the hubs to accommodate the larger bore on the st callipers. When we talk about upsetting the balance in brakes, what we are really talking about is the balance between front and rear. It's called brake bias, and with larger disc upgrades this does change, but in a good way. What I understand is that the front brakes do the most work and the only issue there may be is to upgrade the rear brakes more than the front so the bias is now shifted to the rear brakes instead of the front. You can technically keep the drum brakes at the rear and not change them, it is just preference on how you want it to look. 300mm disc kit from puma speed includes discs pads and larger calipers, bolts. Fiesta ST150 Stage 2 Front Brake Upgrade Kit (300mm) - Fiesta ST150 Mk6 - Brake - Upgrade Kits - Pumaspeed Milltek Ford Performance Tuning Milltek Sport Exhaust Ford Fiesta Focus ST RS Parts Specialist Hello mate, I didn't bother doing the front upgrade as I am happy with the brakes as they are, other than the travel in the pedal which I'm taking too Ford too get it bled via one of their machines. I suppose it would be a very good upgrade but don't facing drilling the hubs or anything and the stopping power is decent at the moment. Let me know if you do it and how you get on with it. Quote Link to comment Share on other sites More sharing options...
juniiior1.0T Posted December 7, 2023 Share Posted December 7, 2023 On 14/1/2021 at 22:46, Eatonm112 said: Tengo un Fiesta Mk7 con llantas de 16 pulgadas y quería ver si podía conseguir discos del Focus ST 170 con las pinzas del Mondeo y aquí está el resultado. https://photos.app.goo.gl/LPzsxtir9ChMqiVBA https://photos.app.goo.gl/xH4cLjC71jezLtHj9 Los resultados son fantásticos, mucho mejores que con la configuración del Fiesta ST que tenía antes. Tengo el Fiesta ST estándar configurado en la parte trasera, pero planeo cambiar los discos por unos de 280 mm de un Focus ST170. El 14/1/2021 a las 22:46, Eatonm112 dijo: Tengo un Fiesta Mk7 con llantas de 16 pulgadas y quería ver si podía conseguir discos del Focus ST 170 con las pinzas del Mondeo y aquí está el resultado. https://photos.app.goo.gl/LPzsxtir9ChMqiVBA https://photos.app.goo.gl/xH4cLjC71jezLtHj9 Los resultados son fantásticos, mucho mejores que con la configuración del Fiesta ST que tenía antes. Tengo el Fiesta ST estándar configurado en la parte trasera, pero planeo cambiar los discos por unos de 280 mm de un Focus ST170. ¿Quieres añadir algún adaptador? O fue plug and play, gracias 1 Quote Link to comment Share on other sites More sharing options...
