KingCraigx Posted March 24, 2020 Share Posted March 24, 2020 Hello, I have replacement LEDs for my reverse bulbs. I have watched a few videos on YouTube and it looks like after undoing the wingnut and clip, it just pulls off. However mine does not and looks to be stuck down in the top edge corner. Has anyone replaced their MK8 Reverse lights or had this part off? I can’t even pry it off with a trim tool, so it’s got to be bolted down else where. thanks. Quote Link to comment Share on other sites More sharing options...
JanWebster Posted March 25, 2020 Share Posted March 25, 2020 Once you have undone the wing nut there are no other fasteners. It's just a matter of running the trim removal tool along the edge and "wiggling".as the bulb-cluster can be a bit unco-operative. Also check that the LED is held securely in place. The CSUK ones may not fit snugly; my husband had to use a bit of gaffer-tape to keep one of the bulbs secure. Quote Link to comment Share on other sites More sharing options...
KingCraigx Posted March 25, 2020 Author Share Posted March 25, 2020 Thanks, I’ll give it another go. It’s must be stuck on there good as it’s never been off the car before. Thanks. Quote Link to comment Share on other sites More sharing options...
Mavroz Posted March 26, 2020 Share Posted March 26, 2020 Do all Mk8 models not have led lamps in the light clusters or is it the lower end models that have standard filament lamps? I think the 2020 models are all led lamps other than the front fog/cornering lamps are they not. Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted March 26, 2020 Share Posted March 26, 2020 3 hours ago, Mavroz said: Do all Mk8 models not have led lamps in the light clusters or is it the lower end models that have standard filament lamps? I have a 2018 price list which refers to "LED night signature to rear lamps" on Titanium and above. I assumed that meant just the normal red lights? Whatever, I find the (twin) reverse lights on my car are excellent as standard, unlike my last car whose single reverse light was worse than a candle. I did swap that for an LED which made an improvement. Quote Link to comment Share on other sites More sharing options...
KingCraigx Posted March 26, 2020 Author Share Posted March 26, 2020 6 hours ago, Mavroz said: Do all Mk8 models not have led lamps in the light clusters or is it the lower end models that have standard filament lamps? I think the 2020 models are all led lamps other than the front fog/cornering lamps are they not. You are somewhat correct. The rear lights are all LED other than the reverse on mine (not sure on indicators) Quote Link to comment Share on other sites More sharing options...
Mavroz Posted March 26, 2020 Share Posted March 26, 2020 I presumed they were all led, including the number plate lights. Not that I have ever noticed and doubt I will ever change them. Quote Link to comment Share on other sites More sharing options...
Hair Posted March 27, 2020 Share Posted March 27, 2020 I have MK8 2018 Titanium and it has filament reverse and turn signal bulbs. Changed them leds of course. 😁 Ceuk sells led sequental side repeaters, ordered because I have led driving lights so dynamic signals to mirrors too.. Led sequental side repeaters MK8 Quote Link to comment Share on other sites More sharing options...
KingCraigx Posted March 29, 2020 Author Share Posted March 29, 2020 On 3/27/2020 at 7:24 AM, Hair said: I have MK8 2018 Titanium and it has filament reverse and turn signal bulbs. Changed them leds of course. 😁 Ceuk sells led sequental side repeaters, ordered because I have led driving lights so dynamic signals to mirrors too.. Led sequental side repeaters MK8 I’ve just pre-ordered those led sequential side indicators from ceuk! I’ve tried again with the reverse light, I can’t get the unit off the car at all... using way too much force and it still won’t budge from one corner. Quote Link to comment Share on other sites More sharing options...
Hair Posted March 29, 2020 Share Posted March 29, 2020 49 minutes ago, KingCraigx said: I’ve just pre-ordered those led sequential side indicators from ceuk! I’ve tried again with the reverse light, I can’t get the unit off the car at all... using way too much force and it still won’t budge from one corner. Yeah, its tight for sure. You just to have wiggle it little side by side and it should eventually come loose. Quote Link to comment Share on other sites More sharing options...
