Rottman Posted March 26, 2020 Share Posted March 26, 2020 HELP my mk5 vignaile has locked me out both key fobs won't work tried blade key for manual operation but this failed to open it all garage are closed due to Corona so potentially it could sit there for months 馃槬 If anyone has info or a hack 馃 cheers chris Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted March 26, 2020 Share Posted March 26, 2020 HELP my mk5 vignaile has locked me out both key fobs won't work tried blade key for manual operation but this failed to open it all garage are closed due to Corona so potentially it could sit there for months [emoji26] If anyone has info or a hack [emoji847] cheers chrisJoin this group on Facebook, someone will be able to help youhttps://www.facebook.com/groups/693277794183606/Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted March 26, 2020 Share Posted March 26, 2020 Have you tried both blades? There should be no problem opening the door manually with the blade. Once you remove the cover off the door handle you should be able to turn the blade, it can be a bit stiff so you may need to hold the blade with a pair of pliers for leverageSent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Rottman Posted March 27, 2020 Author Share Posted March 27, 2020 Many thanks jonro I'll try that but will it start if not detecting key as it's keyless start聽 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted March 27, 2020 Share Posted March 27, 2020 There is a place to put the key in the central armrest at the front, you drop the fob into it and it 'should' respond.Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted March 27, 2020 Share Posted March 27, 2020 Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Rottman Posted March 27, 2020 Author Share Posted March 27, 2020 Yes I'm in used pliers to turn lock thanks again jonro but no start 馃槬 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted March 27, 2020 Share Posted March 27, 2020 You will probably need to charge the car battery Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Rottman Posted March 27, 2020 Author Share Posted March 27, 2020 3 hours ago, Jonro2009 said: You will probably need to charge the car battery Sent from my SM-G965F using Tapatalk 聽 You were spot on flat battery got AA I must have left something on when cleaning 馃檮 thanks very much for your help 馃 2 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted March 27, 2020 Share Posted March 27, 2020 No problem, glad to have helped a little.You should join our group, it really I as a huge pool of knowledge and a friendly place to be, Just what we need at times like this. I can hand on heart say we have no trolls in the group and we all help each otherSent from my SM-G965F using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
