Boot 12v Socket
I have a 2019 Ford Focus. What is involved in instaling a a 12volt socket in the boot?
Paul
I fit them in vans for a living
you will need an ignition live either from the fuse box or I sometimes use the heater live .fuse it with a 20amp fuse
you can go for a permanent live if you require same method
you’ll probably have an earth connection in the boot mine I think has one either side most of the effort will be putting the wire behind the carpet .The wire ideally should be in conduit or taped up for extra protection
thank you
