Little dent in interior door.
Hi all so I've noticed this little in dent on my driver side interior door.
Dont know how it got there but does any one have any ideas on how to fix ?
Cheers everyone x
Gosh, that's tiny but right in your eye line so would be annoying! You could try running a hairdryer on it gently, as most plastics have a 'memory' that will be enacted on some heat. Failing that, there are plenty of 'smart' mobile repair guys that'll fix it invisbly, but maybe financially wait till you have a bit more than that single blemish to call them.
Is that hard plastic or is it soft touch?  I think it's soft touch, and caused by grabbing the door while holding keys etc.  Very annoying but I don't know of a fix unfortunately! :sad:
As said above but try with a hot air paint stripper it get to a higher temperature then a hairdryer, gently warm the aria and see if it comes back in shape.
if it doesn't come back let the aria cool down and start over again
but if it's punctured all of the above won't work and then you could look for an other.
This is the kind of 'smart' repair I was talking about. Someone local is bound to be able to fix this easily... (Oh, play with volume off!)
leave  well alone..you will only make it look worse ..
It is soft touch guys thank you for your reply gonna try some heat and then pay some one if that dosnt work it is annoying because how small it is lol
