Red cog lite on
No codes stored but in limp mode any ideas
Outside temperature below 0 degrees? The "cog" is meant to be a snowflake.
Powertrain warning light. It means something isn't right somewhere in the engine or gearbox. Could be a faulty sensor or something more.
You need to get it checked asap, especially if the EMS has put the car into limp mode to protect itself from further damage.
What are you using to check the codes?
