Sync 3 DAB files
Can anybody point me in the direction for the DAB file please.
AE I think I’m looking for. Thanks
Anybody 🥺
Sure there Linked in the 3.4 update thread. Near the end.
Matt
Matt
Must of missed it. Will check again. Cheers
They’re definitely in there or the Russian forum.  Look at the top post on the Russian site and all the different files are split up neatly.
pretty sure I’ve got a copy so worse case give me another shout and I’ll find jt
Will have a look on the laptop mate. Can’t  use the Russian sites on my phone doesn’t translate. Thanks ill get back to you if I can’t find them
Got them mate. You were right nice and easy to find. Hopefully can fix the logo issue now after downgrading back to 3.4 base.
dont suppose you’ve updated the APIM firmware have you?
Yes - used FORScan beta version. It’s not for the faint of heart.  I haven’t been that scared since I upgraded my clocks on a mk2.5 😅
It worked fine - I screwed up and didn’t update the last 2 calib files (I mistakenly thought they were for the PCM ECU and didn’t want to touch them.  Result: blank screen and DTC codes just said “unit does not support DRC”.  Oops! Flashed the last 2 files and it worked immediately.
I never had radio logos or call screen at all until I upgraded - takes about 30/40 minutes too so make sure your laptop and vehicle have enough juice!
I’ll attempt but this forscan says no update ?
  • 3 weeks later...
Sorry for the delay I don’t get email notification last anymore for some reason.
im not sure what mine said.  I thought I had more greens than that.  Not to pass the buck but I honestly don’t know the answer and given it’s firmware, I would await confirmation from someone who actually knows the situation lol
I had thr same.
Select custom and then select the firmware files found in the 3.4 upgrade thread. On page 3 from memory.
Matt
Yea can’t find a clear answer so haven’t bothered
As Matt said, I believe that is what I did (custom, files from this thread) but same warning - my memory is foggy and I don’t want you to brick it.
