mickter Posted May 2, 2020 Share Posted May 2, 2020 Hi All. I have a 2016 b-max 1.5 tdci , as we are in lockdown have only used car once a week, have noticed stop/start not working,thought battery could be low, how are you supposed to connect earth lead from charger to battery. can only just see it let alone reach it, also have small starter pack just in case , have read alternator will not fully charge battery if its too low Help, Mick. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 2, 2020 Share Posted May 2, 2020 You don't connect to the earth on the battery you connect to the body earth which is close by don't know the exact location on a Bmax, it's bad practise to connect to the battery.. On the Cmax it's to the right of the battery box near the bulkhead it's got a heavy cable connected to it might be similar on the Bmax Quote Link to comment Share on other sites More sharing options...
mickter Posted May 2, 2020 Author Share Posted May 2, 2020 Should read c-max , brain not in gear. Thanks for reply Mick. 1 Quote Link to comment Share on other sites More sharing options...
mickter Posted May 2, 2020 Author Share Posted May 2, 2020 C-Max 1.5 tdci with stop/start. battery is Varta EFB 75ah. 700A SAE/EN T7. Have a Ring Automotive charger 8 RCB208 with low/high setting can I use this to charge battery in situ and still connected , or must I buy special charger. Thanks Mick. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 2, 2020 Share Posted May 2, 2020 No reason why not. 1 Quote Link to comment Share on other sites More sharing options...
mickter Posted May 4, 2020 Author Share Posted May 4, 2020 Put battery on charge (low setting) after a few hours battery charged up. Thanks Mick. 1 Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 4, 2020 Share Posted May 4, 2020 3 hours ago, mickter said: Put battery on charge (low setting) after a few hours battery charged up. Thanks Mick. Great, stop,start may still not work there are a lot of parameters that have to be met, battery charge, engine temp not to hot or to cold, electrical load and a/c to name but a few. I drive 25 miles to the nearest town and I don't get stop start straight away under bonnet temp to high. Quote Link to comment Share on other sites More sharing options...
mickter Posted May 5, 2020 Author Share Posted May 5, 2020 Did weekly shop yesterday , Stop/Start working again. Thanks for help. Mick. 1 Quote Link to comment Share on other sites More sharing options...
mickter Posted May 27, 2020 Author Share Posted May 27, 2020 Stop/start n/w again so bought special charger, took over 24 hrs to charge fully, lost charge again,had battery checked at garage , £172 for new one fitted. apparently alternator is over £300. stop/start is not cheap. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted May 27, 2020 Share Posted May 27, 2020 Where you wearing a flourrecent jacket, because oh boy they seen you coming way overcharged. Stop start isn't pricey but old battery's can be as you found out pays to shop around, the correct batter from Ford ,is well at my dealers , cheaper than aftermarket Quote Link to comment Share on other sites More sharing options...
