Ford Focus 2009 music remote control module not working
Hi guys.
I own ford focus 2009 and the music control module attached to steering wheel doesn't work.
Do you think It might be a fuse? If so do you wknow which fuse it is?
The radio remote on the steering column is basically just a simple resistor switch assembly that is connected to the radio with just 2 wires. Every button on the switch assembly has a different resistance. Based on the resistance the radio can determine which of the buttons is pressed.
Because of the simplicity there are only a few possible causes of the problem:
1. The resistor switch assembly is defective.
2. There is a wiring defect.
3. The radio is defective.
Thank you very much for this information.
I think it must be number 1 or 2 as I have changer radio for one with android and it didnt work on either.
Would you know what's the easiest way to test if it's the switch that is defective?
Bart
  • 4 weeks later...
Hi Mate
The answer was option2 there is wiring defect, is there any tutorial how to run a wire ?
thanks
Bart
