Broadld Posted May 11, 2020 Share Posted May 11, 2020 Good morning All, Come to use my car as I haven't used it for sometime due to the current COVID situation. It is keyless start and the remote unlocking doesn't work. I have opened the key up and tried to use the physical key to open the door. But it won't open. I'm unsure when I locked it last if I double pressed the lock button. Which I think deadlocks it. Would this prevent the physical key from unlocking the driver's door? Anyone got any ideas how I can get in to open bonnet to charge the battery? Thanks In advance. Quote Link to comment Share on other sites More sharing options...
sussamb Posted May 11, 2020 Share Posted May 11, 2020 Someone posted earlier that in a similar situation the key worked on the passenger door, have you tried that? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 11, 2020 Share Posted May 11, 2020 I don't think there's a barrel on the passenger side on a Mk3? Even if deadlocked you should be able to open it with the physical key. The top of the key blade fits back into the fob to give you more leverage. If you really can't get locks open, you can jack up the front of the car and attach a jump pack to the battery cable to the starter and earth to any solid lump of metal. That should energise the car for the remote locking to work again. Don't hit the starter relay with the jumper cable if you parked in gear! Quote Link to comment Share on other sites More sharing options...
sussamb Posted May 11, 2020 Share Posted May 11, 2020 2 hours ago, TomsFocus said: I don't think there's a barrel on the passenger side on a Mk3? Quite right, my error 🙂 1 Quote Link to comment Share on other sites More sharing options...
