Fault codes.
So I've recently got an elm327 cable and forscan to add autlocking doors to my 2017 Focus titanium x 1.5 diesel before I done anything I done a DTC read and the car had a few fault codes to do with the right indicator which was no big issue. I went ahead and added the auto locking doors onto my car went back and done another dtc read and the car has thrown up alot of codes, I'm not sure if these codes have appeared as a result of the car shutting down to add this feature and the ecu is just storing these codes as it couldnt communicate with certain modules at that time.
Ive thought about just clearing these codes and going for a drive and re testing it thiught id check with the forum first.
Also a note there is no warning lights on the dash and everything seems to be working as normal.
Code: B1206 - Crash Occurred
Code: B11D4 - Low Speed Collision Mitigation By Braking Disabled
Code: U0140 - Lost Communication With Body Control Module-Module: Powertrain Control Module
Code: P068A - ECM/PCM Power Relay De-Energized - Too Early
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Code: U0140 - Lost Communication With Body Control Module-Module: Steering Angle Sensor Module
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module-Module: Front Distance Sensing Module
Code: U0140 - Lost Communication With Body Control Module-Module: Front Distance Sensing Module
Code: U0401 - Invalid Data Received from  ECM/PCM A
Code: U0140 - Lost Communication With Body Control Module-Module: Antilock braking system
Code: U0126 - Lost Communication With Steering Angle Sensor Module-Module: Antilock braking system
Code: U0140 - Lost Communication With Body Control Module-Module: Restraint Control Module
Code: U0257 - Lost Communication With Front Controls / Display Interface Module
Code: U0140 - Lost Communication With Body Control Module-Module: Parking Aid Module
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module-Module: Parking Aid Module
Code: U0140 - Lost Communication With Body Control Module-Module: Headlamp Control Module
Code: B1D07 - Right Turn Indicator-Module: Body Control Module
Code: B1098 - Left Position Light
Code: U0202 - Lost Communication With Door Control Module D-Module: Passengers Door Control Unit
Code: U0201 - Lost Communication With Door Control Module C-Module: Drivers Door Module
Code: B1030 - Left Front Seat Heater
Code: B1032 - Right Front Seat Heater
Code: U2100 - Initial Configuration Not Complete
Code: U0140 - Lost Communication With Body Control Module-Module: Heating Ventilation Air Conditioning
Code: U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module-Module: Heating Ventilation Air Conditioning
Code: U0140 - Lost Communication With Body Control Module-Module: Instrument Panel Control Module
Code: U0199 - Lost Communication With Door Control Module A-Module: Instrument Panel Control Module
Code: U0200 - Lost Communication With Door Control Module B-Module: Instrument Panel Control Module
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module-Module: Instrument Panel Control Module
Code: U0151 - Lost Communication With Restraints Control Module-Module: Instrument Panel Control Module
Code: U0100 - Lost Communication With ECM/PCM A
Just due to a bcm rewrite.
Clear them all.
