Power Steering Leak
I have a 2006 focus 1.8tdci with a sudden big leak at the O ring hose / rack connection. Replaced o rings and a/h rack but still leaking. The clamp does not seem to hold the pipes in tight and fluid passes out. I must need new hoses, but can’t find correct set of hoses for electric pump version That is Behind/under headlamp. I need a part number or motor factors where I can get correct new  hoses. Car has done 200k so can’t justify Paying dealer prices . Two O rings were £13!  Thanks guys
Go on Catcar.info, enter your vin and then you'll see the parts for your actual build. But you must put in your vin to get the relevant info.
Better try 7zap.com....there's more detailed description of the parts. Of course VIN is required.
