Fiesta1.25 Posted May 18, 2020 Share Posted May 18, 2020 Hi just worndering if this is normal behaviour of my aircon compressor, as you can see in the video the clutch on the compressor engages then dis engages every few seconds. Also if you look at the pressure of the system it drops away down to low and climbs back up to above the green zone. Hope someone can shed some light on this. Quote Link to comment Share on other sites More sharing options...
nicam49 Posted May 18, 2020 Share Posted May 18, 2020 Yeah, I'm familiar with that. It means the pressure in the system is low, so the compressor clutch keeps on engaging/disengaging. You've most likely got a leak, probably the condenser, which is the radiator-looking thing. Quote Link to comment Share on other sites More sharing options...
Fiesta1.25 Posted May 18, 2020 Author Share Posted May 18, 2020 I replaced the condenser and compressor last year, I had the system vacuumed and re gassed a few months ago and that went ok. Quote Link to comment Share on other sites More sharing options...
nicam49 Posted May 18, 2020 Share Posted May 18, 2020 So, get the pressure checked again. Then it can eliminated. But the above is the most likely cause. Never assume! 1 Quote Link to comment Share on other sites More sharing options...
Fiesta1.25 Posted May 18, 2020 Author Share Posted May 18, 2020 So, get the pressure checked again. Then it can eliminated. But the above is the most likely cause. Never assume! Ok cool I will get the system pressure checked thank you for your help really appreciate it [emoji106] Quote Link to comment Share on other sites More sharing options...
