FSTA Posted June 11, 2020 Share Posted June 11, 2020 My March 2015 reg Fiesta is showing the " Tyre Sensor not recognised" warning, so I guess it's time for new sensors. The display unit is the type that shows only a low tyre pressure warning but not the actual pressures. Has anybody got useful tips for sourcing compatible items, and/or knows the Ford part number? Is there any way to identify which one is the failing one and after replacing it, is there any reprogramming to undertake? But--has anyone had any success with DIY battery replacement modification as a cheaper option? Any advice would be appreciated, please. Quote Link to comment Share on other sites More sharing options...
cjay1 Posted June 12, 2020 Share Posted June 12, 2020 Have you tried resetting tpms I get this warning on mine sometimes but a reset fixes it. Quote Link to comment Share on other sites More sharing options...
LesPes Posted June 12, 2020 Share Posted June 12, 2020 https://www.ebay.co.uk/itm/FORD-FIESTA-MK7-C-MAX-MK2-FOCUS-MK3-TYRE-AIR-PRESSURE-SENSOR-13-2017-SQUARE/333498833306?epid=12038159850&hash=item4da614599a:g:~aIAAOSwsdteMaXt. These should be what you want. Kwik fit done mine for free when i changed them over, just gave the guys "a drink" Quote Link to comment Share on other sites More sharing options...
statts Posted June 12, 2020 Share Posted June 12, 2020 Hello Have you had new tyres or alloy wheel refurbishment on your car and if so did they put the sensors back in? I had the same problem and it turned out i had the wheels refurbished and the sensor hadn't been put back in. Luckly i wasn't paying for it because my main dealer (Pye Motors Morecambe) charged £115 to replace them. At least they are made with good quality parts. Spoke to a tyre fitter and they said Chrysler/Jeep/Dodge sensors are the worst but Ford/Vauxhall sensors last ages. hope this helps Quote Link to comment Share on other sites More sharing options...
FSTA Posted June 14, 2020 Author Share Posted June 14, 2020 Thanks. No recent tyres or wheel changes so something new going on. A reset did remove the warning, but it returned. (I did check tyre pressures, but this is not the same warning as when a tyre has deflated) As the sensor is "not recognised," I guess it is not transmitting. Is there any quick way of identifying which one is the faulty one? Just for my information, where is the receiver situated that gets the sensor transmission? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 14, 2020 Share Posted June 14, 2020 Could just be a dead battery in a sensor.Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
FSTA Posted June 14, 2020 Author Share Posted June 14, 2020 Yes, that's very likely! So How can I identify the faulty one and has anyone had success with a DIY battery replacement instead of a new sensor? Does a new sensor need training/pairing to the car? Quote Link to comment Share on other sites More sharing options...
FSTA Posted June 14, 2020 Author Share Posted June 14, 2020 On 6/12/2020 at 9:29 AM, LesPes said: https://www.ebay.co.uk/itm/FORD-FIESTA-MK7-C-MAX-MK2-FOCUS-MK3-TYRE-AIR-PRESSURE-SENSOR-13-2017-SQUARE/333498833306?epid=12038159850&hash=item4da614599a:g:~aIAAOSwsdteMaXt. These should be what you want. Kwik fit done mine for free when i changed them over, just gave the guys "a drink" Thanks, but those are used ones; I would not expect them to last long. Quote Link to comment Share on other sites More sharing options...
fgservo Posted June 14, 2020 Share Posted June 14, 2020 When i change my wheels, 16 to 17, i brought new sensors in Ford dealership, 30€ a set of 2. Is not that much for some people, but you will know that works. Quote Link to comment Share on other sites More sharing options...
LesPes Posted June 15, 2020 Share Posted June 15, 2020 20 hours ago, FSTA said: 11 hours ago, FSTA said: Thanks, but those are used ones; I would not expect them to last long. Just showing what type you need. Ford ones last longer go and pay their prices Quote Link to comment Share on other sites More sharing options...
FSTA Posted June 26, 2020 Author Share Posted June 26, 2020 Thanks for the responses.However for the benefit of any others who come across this problem, here is the result of my research and experience. There is a lot of misinformation on the web and from tyre fitters. The costs involved are varied. (Main dealer looking for over £100! and Kwik Fit for £80} There are two slightly different sensor types.If you have the system that identifies which tyre is at fault it is easy to do so, but if only a general warning is available, then it will require a 5 minute check with a specialist tool. (Not just an OBD reader). Some fitters and my Ford dealer will do this (reluctantly!) for free. (A drink would be nice!) The sensor can be purchased from £8 (china) up to £50ish on line. Around £18 looks competitive, but see later for coding costs. There are two interchangeable fitting styles to put it onto the rim; one uses a metal valve stem with a retaining nut and the other a push in rubber (non-corroding) valve stem. There are various shapes of sensor housing design, but all are OK. Removing the tyre, fitting the new valve & sensor are straightforward, (£6 at my local tyre shop) . Coding and pairing.----the sensor needs to be coded with its own individual identity/transmission code.This can be done with a specialist tool (again not an OBD reader) "TPMS Warehouse UK" do this on request free with a purchase. Their sensor was £25 incl delivery. Once fitted, I did the following, Inflate to correct tyre pressure then ( as in the car specific guidance supplied on line by TPMS Warehouse.)---- Close doors, press brake pedal & release. Use ignition key to switch on (NOT START) dash lights, switch off, switch on & switch off again, then switch on. Press and release brake pedal and then switch off. Repeat the triple switch on/off cycle, ending with brake press and switch off. Horn bleeps. Process completed. (This process does vary slightly with different models) All seems good so far at a total cost of £31. I am not on commission, but I was impressed with the help given by phone by TPMS warehouse. Further comments---Some on-line information suggests that the individual sensorcoding is not needed and that either the process stated or even just resetting the infotainment display and then driving for 15 mins will suffice. I don't know, but as the coding is available, why not do it and be sure. Regarding battery replacement----I dismantled the old sensor. It is not designed for this, but the glued housing can be seperated and the electrics eased out. The battery is one with "legs" to solder onto a small PCB but is NOT a standard button battery as it is a High temp long life version with the legs. Availability seems to be zero in the UK, which is a shame as replacement would be relatively easy and inexpensive for a DIY job. Indeed the design seems to be meant to thwart routine battery replacement, although this looks as though it will be an increasingly needed task as the first generation of these sensors starts to run out in the UK. Hope others benefit from my experience. 1 1 Quote Link to comment Share on other sites More sharing options...
fgservo Posted June 26, 2020 Share Posted June 26, 2020 The sensors i brought in Ford as like this (pic) with rubber seal, 60€ 4 sensores Just did a reset in center console and work perfect. This sensor monitor the 4 tires, if any drop 0.3 psi, you will get a warning. With that sensor you will get a warning about which tyre is faulty? Quote Link to comment Share on other sites More sharing options...
brains_t Posted June 28, 2020 Share Posted June 28, 2020 On 6/26/2020 at 9:42 PM, fgservo said: The sensors i brought in Ford as like this (pic) with rubber seal, 60€ 4 sensores Just did a reset in center console and work perfect. This sensor monitor the 4 tires, if any drop 0.3 psi, you will get a warning. With that sensor you will get a warning about which tyre is faulty? What is the shape on the flip side? Quote Link to comment Share on other sites More sharing options...
fgservo Posted June 28, 2020 Share Posted June 28, 2020 Picture from google Quote Link to comment Share on other sites More sharing options...
FSTA Posted June 29, 2020 Author Share Posted June 29, 2020 On 6/26/2020 at 9:17 PM, FSTA said: Once fitted, I did the following, Inflate to correct tyre pressure then ( as in the car specific guidance supplied on line by TPMS Warehouse.)---- Close doors, press brake pedal & release. Use ignition key to switch on (NOT START) dash lights, switch off, switch on & switch off again, then switch on. Press and release brake pedal and then switch off. Repeat the triple switch on/off cycle, ending with brake press and switch off. Horn bleeps. Process completed. (This process does vary slightly with different models) ADDENDUM-----I have been told by those helpful folk at TPMS Warehouse that this sequence does not always work on some models, but if so, any garage with diagnostics can edit the coding to insert the identity of the new sensor. Their invoice gives this identity number Quote Link to comment Share on other sites More sharing options...
