Fran111348 Posted June 14, 2020 Share Posted June 14, 2020 Hey i got mk2 2007 focus with knocking coming from both sides on front sounds coming from i think where inner cv joint enter transmission its mostly over bumps it dosent happen when turning ive replaced sway bar bushings drop links tie rod ends there is a clunk in drive shaft when u grab it pull in an out on it got bit leakage from driveshaft seal any ideas much appreciated Quote Link to comment Share on other sites More sharing options...
kacy Posted June 17, 2020 Share Posted June 17, 2020 I had the same issue a few years ago. Turned out to be knackered top shock mounts. Quote Link to comment Share on other sites More sharing options...
catfish79 Posted June 20, 2020 Share Posted June 20, 2020 Interesting I have the same knocking noise.Car never fails MOT on it though and this has been going on for years.Did a ball joint thinking I’d found it lol.Top shock mount sounds likely Quote Link to comment Share on other sites More sharing options...
