Rundle123 Posted June 25, 2020 Share Posted June 25, 2020 Hi there I just recently noticed today my engine coolant level has dropped below the minimum line, is there any reason for this? I’m going to top it up as it’s not really a lot the coolant colour is pink, would it be okay to just top it up? Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted June 25, 2020 Share Posted June 25, 2020 You don't say if this has happened suddenly or over time. There are lots of reasons for loss of coolant from leaking hoses or faulty pressure cap to failing head gasket so best thing first of all is to top it up to max when cold and monitor to see what happens. Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 9 minutes ago, Comares2001 said: You don't say if this has happened suddenly or over time. There are lots of reasons for loss of coolant from leaking hoses or faulty pressure cap to failing head gasket so best thing first of all is to top it up to max when cold and monitor to see what happens. I couldn’t say when if I’m honest, I had my service in December but I can’t remember or say if the coolant was actually flushed and refilled Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted June 25, 2020 Share Posted June 25, 2020 Top it up and keep checking the level every so often to see if it drops. If there's no noticable drop after a month I wouldn't worry about it. It might've never been topped up or changed in the 7 years it's been on the road lol. Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 23 minutes ago, Luke4efc said: Top it up and keep checking the level every so often to see if it drops. If there's no noticable drop after a month I wouldn't worry about it. It might've never been topped up or changed in the 7 years it's been on the road lol. Yeah that’s a good point lol, I’ve only had the car for a year July, the only reason I believe it may not have been changed in the service in December is because the garage seemed to want to get my car out in a hurry as when I went to use the windscreen reservoir A couple weeks later it was still empty so something tells me they didn’t bother doing much under the bonnet lol Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted June 25, 2020 Share Posted June 25, 2020 That coolant doesn't have to be changed its there for life as long as the 50/50 concentration is maintained. Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 9 minutes ago, Comares2001 said: That coolant doesn't have to be changed its there for life as long as the 50/50 concentration is maintained. So nothing at all should be lost? Quote Link to comment Share on other sites More sharing options...
isetta Posted June 25, 2020 Share Posted June 25, 2020 in theory nothing should be lost. I had a Focus for 8 years and I never added any coolant in all that time (but some cars do seem to need a top up now and then - but talking about months at least). But I had Fiesta 1.6tdci on which the coolant never seemed to like being up at the max. if I topped up to max, over next few weeks it would go to just below min, but then it would stay there, but if I topped up to max again it would go down to just below min again after a while and then stay there. Never really worked out why but had car for years and it did not seem to do any harm. check it on level ground when cold 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 That’s strange isn’t it? Must be a reason behind but at least you had no clear issues with it, I tend to overthink the worst of things so I will just have to top it up and monitor like everyone has said 18 minutes ago, isetta said: in theory nothing should be lost. I had a Focus for 8 years and I never added any coolant in all that time (but some cars do seem to need a top up now and then - but talking about months at least). But I had Fiesta 1.6tdci on which the coolant never seemed to like being up at the max. if I topped up to max, over next few weeks it would go to just below min, but then it would stay there, but if I topped up to max again it would go down to just below min again after a while and then stay there. Never really worked out why but had car for years and it did not seem to do any harm. check it on level ground when cold Quote Link to comment Share on other sites More sharing options...
wordchild Posted June 25, 2020 Share Posted June 25, 2020 Hello folks, Think it would be worth monitoring the coolant level - you could make a pencil mark on the expansion tank to do this - though it may not be anything major to worry about. That said, Connor I'm a bit curious as to what engine you have? I ask because the 1.6tdci has a (I think...) fairly common fault where the thermostat housing leaks and the coolant level obviously drops. My previous (2006) mk6 and current (2011) 1.6 diesels have both had this fault. If yours isn't the 1.6 diesel you may have less of a concern...! 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 21 minutes ago, wordchild said: Hello folks, Think it would be worth monitoring the coolant level - you could make a pencil mark on the expansion tank to do this - though it may not be anything major to worry about. That said, Connor I'm a bit curious as to what engine you have? I ask because the 1.6tdci has a (I think...) fairly common fault where the thermostat housing leaks and the coolant level obviously drops. My previous (2006) mk6 and current (2011) 1.6 diesels have both had this fault. If yours isn't the 1.6 diesel you may have less of a concern...! That’s a good shout didn’t think of the pencil trick thanks! I have a 1.25 Zetec, ah right I see that’s odd and not ideal! Is it something that can be fixed easily enough ? Quote Link to comment Share on other sites More sharing options...
wordchild Posted June 25, 2020 Share Posted June 25, 2020 8 minutes ago, Rundle123 said: That’s a good shout didn’t think of the pencil trick thanks! I have a 1.25 Zetec, ah right I see that’s odd and not ideal! Is it something that can be fixed easily enough ? Hi again, No problem 🙂 & you'd need someone more mechanical than me to answer that properly but I imagine it depends if there's a coolant leak & if so, where from - eg changing a split hose or tightening a connection wouldn't be too tricky i guess. 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 29 minutes ago, wordchild said: Hi again, No problem 🙂 & you'd need someone more mechanical than me to answer that properly but I imagine it depends if there's a coolant leak & if so, where from - eg changing a split hose or tightening a connection wouldn't be too tricky i guess. That’s fair enough, hopefully it is something like a split hose or a loose connection somewhere! Thank you Quote Link to comment Share on other sites More sharing options...
wordchild Posted June 25, 2020 Share Posted June 25, 2020 11 minutes ago, Rundle123 said: That’s fair enough, hopefully it is something like a split hose or a loose connection somewhere! Thank you Hope so 🙂 The Haynes manual points out that leaked coolant often leaves a stain (can be like a whitish crystalline deposit) which might help find the leak (if that's the problem). But as I say I'm hoping someone more mechanical pops up to help too! 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 2 hours ago, wordchild said: Hope so 🙂 The Haynes manual points out that leaked coolant often leaves a stain (can be like a whitish crystalline deposit) which might help find the leak (if that's the problem). But as I say I'm hoping someone more mechanical pops up to help too! Just got home from work and had a quick scan under the bonnet and whilst the engine was running I couldn’t see any obvious leaks from pipes in my view Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 25, 2020 Author Share Posted June 25, 2020 2 hours ago, wordchild said: Hope so 🙂 The Haynes manual points out that leaked coolant often leaves a stain (can be like a whitish crystalline deposit) which might help find the leak (if that's the problem). But as I say I'm hoping someone more mechanical pops up to help too! Also I’ve been looking online to see if Nyone else has had similar issues and I saw something about someone’s water pump being the problem, I’ve only recently had my Cambelt and water pump done could they have possibly fitted it incorrectly or a faulty one? Quote Link to comment Share on other sites More sharing options...
fleamoo Posted June 26, 2020 Share Posted June 26, 2020 In addition, thread 'Coolant level' started by Piston Head on this forum might be worth checking out before you top up. 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 26, 2020 Author Share Posted June 26, 2020 2 hours ago, fleamoo said: In addition, thread 'Coolant level' started by Piston Head on this forum might be worth checking out before you top up. Thanks mate just had a look very interesting read, I’ve already filled it up for now but I haven’t checked it enough regularly to see if it has changed over time, hopefully that is the case, I’ve booked it in with a local garage to have a look if they can give me an answer Quote Link to comment Share on other sites More sharing options...
Jeipii Posted June 27, 2020 Share Posted June 27, 2020 Check the two plastic connectors connecting to coolant reservoir. It could be slowly dripping from there. Also check that the coolant reservoir is not leaking when it's warmed up. Also a lot of other places where it could leak though. 1 Quote Link to comment Share on other sites More sharing options...
Eng_Ahmad1986 Posted June 28, 2020 Share Posted June 28, 2020 I owned my mk8 fiesta since march 2019, up till now the coolant level is stuck at the max mark, it never dropped even a little bit, knowing that summer temperature here in Egypt reaches 42 Celsius , so I think you have a problem and its better to resolve it before it gets bigger, ecoboost engines doesn't tolerate even a minor leak in the cooling system, I suggest you check the system for internal or external leaks, the dealer has the tools to pressurize the system to check for leaks, please don't neglect the issue for the sake of your engine. 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted June 28, 2020 Author Share Posted June 28, 2020 9 hours ago, Eng_Ahmad1986 said: I owned my mk8 fiesta since march 2019, up till now the coolant level is stuck at the max mark, it never dropped even a little bit, knowing that summer temperature here in Egypt reaches 42 Celsius , so I think you have a problem and its better to resolve it before it gets bigger, ecoboost engines doesn't tolerate even a minor leak in the cooling system, I suggest you check the system for internal or external leaks, the dealer has the tools to pressurize the system to check for leaks, please don't neglect the issue for the sake of your engine. Yeah I think it’s an issue, I’ll be taking it to a local garage tomorrow to have a look and they’re going to pressure test to see if there’s any leaks 1 Quote Link to comment Share on other sites More sharing options...
Rundle123 Posted July 1, 2020 Author Share Posted July 1, 2020 Update- Hi guys went to the garage today they pressure tested the system there was no leaks they checked it and nothing was obviously leaking, I did get my cambelt and water pump changed from there back in March or February and they said once it was fitted there may have been an airlock or something and they forgot to tell me to check the coolant a day or so after as it may go down and I would have needed to put more in, thankfully I noticed it before any serious damage was done! Quote Link to comment Share on other sites More sharing options...
