Mot advisory
Mot advisory
Can anyone shed a light on o/s rear ferule corroded I've looked on utube just says the metal bit at the end of brake hose can I  wire brush it down then wd40 or grease it up or would I be better of to change the brake hose
Wire brush the rust off then grease it, WD40 will not last very long, might as well do the others while you at it.
Don’t get too worried over mot advisories.
I would advise checking it out yourself and if you think it looks bad then replace/repair as required.
You could take it to a different tester next year and he might say nothing about it.
Without seeing it, it’s impossible to give an opinion.
